Furnace turns on when it's off - Fiberglass RV
Old 04-26-2015, 06:46 PM   #1
Trailer: Casita 17' SD
Last night was my first in my new (used) 17' SD. All went fine -- except I was awakened repeatedly during the night by my heater turning on. (Not the heat strip in the air conditioner, but the gas "furnace.") I checked and the thermostat was all the way (and clicked) to the left. It would run for maybe 3-4 minutes, then turn off. Then do so again an hour or two later. Very annoying! I didn't know what to do.
Should I just go ahead and have the thermostat replaced? Could it be something else?
Tangentially, is there a way the heater can be turned off? I guess I could turn off the propane, yes?
Help!
gsmccar is offline   Reply With Quote
Old 04-26-2015, 07:09 PM   #2
Trailer: Casita 17 ft DLX SD
Remove the thermostat from the wall and disconnect the wires connected to the thermostat .Test the thermostat with an ohm meter to see if the thermostat is working properly .I used a hair dryer, set on low to simulate a rise in temperature to see if the thermostat opened on temperature rise. The lockout detent is mechanical and can be visually examined
Old 04-26-2015, 09:18 PM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
I'd just replace the thermostat. Digital ones are cheap these days and work far better.
Charlie Y
Charlie Y
Old 05-07-2015, 05:21 PM   #4
So I called Casita and finally got the problem diagnosed figured out: the little plastic tab on the switch that breaks the connection when the thermostat is turned off had snapped off. Not obvious!
Of course, I can't just replace the plastic switch top, but need to replace the entire thermostat (or just keep sticking a piece of rubber or something in there to break the connection. Kind of a pain -- but cheap!).
As suggested, replacing it with a digital thermostat sounds good. But first off, to remove the old one, I will need to drill out the rivets that attach it to the wall. Is that no biggie? And then the new one, I guess, would likewise be riveted to the wall, yes? I do have a rivet gun -- which I have yet to use.
Old 05-07-2015, 05:46 PM   #5
Greg you have my sympathy. Years ago I was out camping, propane shut off, furnace thermostat shut off (I thought) and at night the temperature dropped inside the trailer into the low 40s... the Suburban tried to come on. I thought a Boeing 747 was trying to land on the roof. Shot out of bed, heart pumping, trying to figure out what was what! Yep, disconnected that crappy thermostat before the next trip. I still haven't replaced it... that's on the to-do list.
Old 05-07-2015, 06:04 PM   #6
A previous owner of our Casita intentionally broke off the on / off lever on the thermostat. Stated he would hit it with his foot when in bed and turn the furnace on (or maybe it was off?) We haven't used the furnace, but to do so we can pop off the thermostat cover and move the switch. We prefer an electric heater
Old 05-07-2015, 06:17 PM   #7
tractors1's Avatar
I suggest putting the new thermostat on with 3M VHB tape instead of rivets. Not like it's an incredibly heavy item.
But then again, I'm not into drilling holes or even hardware (especially rivets.)
Charlie Y
Charlie Y
Old 05-07-2015, 06:45 PM   #8
Dennis mn's Avatar
I had the same thing happen to the thermostat in our Scamp. I ripped it off the cabinet, disconnected the wires and touched them together when I needed heat. On our most recent trip, I bought a thermostat at Home Depo and installed it.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
furnace
goTenna... turns your cell phone into a cell-free 2-way text device accrete General Chat 3 09-01-2014 04:08 PM
Turns out my Trillium weighs more than.... Bee in Canada General Chat 24 05-25-2014 10:16 PM
door lock didn't work -turns out to be an easy fix Daryl and Wendy Problem Solving | Owners Helping Owners 4 08-08-2013 10:57 PM
RVing Turns 100! Patrick M. General Chat 2 06-08-2010 02:11 PM
Log off or turn off? General Chat 0 12-31-1969 07:00 PM
