Hand pump - lead on a good one? - Fiberglass RV
Old 06-26-2008, 06:44 PM   #1
JenPB's Avatar
Trailer: 1972 Compact Jr
Thumbs up
Bought a hand pump from my local RV shop. Finally got all the fittings and installed that baby (hole in countertop and everything) and it started to siphon, then took a dump. Nada. Nothing. ARGH! Don't know if I should return it and try another of the same pump or move on. Clearly this one's a ...
Any leads on a good hand pump?
Otherwise, work on our "new" 1972 Compact Jr. is going well. Finally had the nerve to test the windows today. They seem to be in good shape.
OH! Turned on the propane. Immediately found leaks at tank handle and regulator. Two of three burners worked. The third seems not to get enough fuel to light fully. Pointers?
Jen
jenpb.blogspot.com
Jen
"Nowhere to be and all day to get there." - The Bills
JenPB is offline   Reply With Quote
Old 06-26-2008, 06:45 PM   #2
JenPB's Avatar
Here's the pump I installed:
http://www.vintagetrailersupply.com/Hand_P...l_p/vts-429.htm
Jen
Jen
Old 06-26-2008, 07:06 PM   #3
Trailer: Play Pac ('Egg Krate')
Jen
Just a thought. If it started to siphon and quit. There's an air leak somewhere. May not be the hand pump at all. Try putting your thumb over the spout end and pumping the pressure up a bit. Might be a dud, or not.
Bonnie
Plotting my next adventures...
Bonnie is offline   Reply With Quote
Old 06-26-2008, 08:07 PM   #4
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
Jen.....
Not sure about the hand pump problem and hope you figure it out but i have to say that is a pretty good website and i saved it with my favorites
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 06-26-2008, 08:53 PM   #5
Trailer: 84 16 ft Scamp
I had no luck with RV quality hand pumps either.
Finally I bought one at a yachting store and the problems were over. The one I ended up with mounts below the cabinet and is foot operated. It was a bit more pricey than the RV, but worth it.
Since then my wife and I decided to simplify things and we removed all plumbing and tanks.
For water we use a couple of 1 1/2 gallon clear plastic jugs (originally for olive oil) that we fill from several 6 gallon water cans that are carried in the back of the Blazer. One jug only gets good drinking water. The other one is for washing water.
For gray water, we have a rectangular 2 1/2 gallon jug (originally for mustard, free from a local restaurant) that sits directly under the sink. A flexible hose drains the sink into the jug. This jug is dumped daily.
We have had this system in for about a year and like it best. It is much easier to conserve water when you pour it and dump it daily. We also like the idea of drinking water from our own well for most of our trips. The coffee tastes better also.
Since going this route, I don't remember ever running out of water, fixing a leaking pipe or priming a pump. Wonder why?
Old 06-27-2008, 02:50 AM   #6
Trailer: 1975 Trillium 13 ft / Chevy Astrovan
Just discovered that our slightly leaking hand pump is now squirting. Was looking on the net today and saw a Valterra Rocket hand pump. Any good?
Connie M. is offline   Reply With Quote
Old 06-27-2008, 08:39 AM   #7
West Marine sold one at one time that looked exactly like that, but without the chrome. You could get them in either white or black.
We had one in our Scamp for awhile, but I could never get it to hold a prime.
The pump of choice for yachters is made by Fynspray. A little pricey, but good, I'm told.
It was the problem with pumps and the cost of a Fynspray that caused us to re-think and simplify our water system, as I've noted in another post.
Old 07-06-2008, 11:22 PM   #8
JenPB's Avatar
Post
Well, I ended up dumping the little pump that failed on its first go. Installed the Valteera Rocket Hand Pump with no problems and it's working WONDERFULLY!
Thanks for your pointers and leads!
Jen
Jen
Old 07-20-2008, 08:49 PM   #9
JenPB's Avatar
Post
Kinda wished I would have gotten the pump that works with both city water and the hand pump. But I didn't like how LOW it was. I mean, seriously, my hands would barely fit in that space, let alone a pot to ... catch water in! SO I went with the rocket and here's what it looked like after the installation. Not bad for a girl!
Plus, it seems to work beautifully!
Thanks again. I hope to see some of you on the road this summer.
Jen in Cali
7 days 'til liftoff - WOO HOO!
Jen
Old 07-20-2008, 09:35 PM   #10
Pete Dumbleton's Avatar
When you are pumping with hand pump, the lever can be left forward or back -- In one position the line drains back to the tank; in the other position the line holds its prime.
I have seen three-way pumps in marine world that were hand, electric-tank, and city-water.
In nine years in two trailers, I have only had to replace pumps twice. I like hand be cause it's handy, doesn't use electricity, doesn't waste water and doesn't generate as much gray water.
A lot of this kind of stuf boils down to how much one is trying to make a camping trailer into a stick-built anchored home....
Hand Pump Faucet Priming and Holding Prime? Kevin Poll Problem Solving | Owners Helping Owners 5 06-13-2010 07:37 AM
old Coleman Hand Rocker Pump Peggy Problem Solving | Owners Helping Owners 1 08-28-2009 09:05 PM
broken hand water pump cyndi H Problem Solving | Owners Helping Owners 21 10-21-2008 05:58 AM
No more hand rocker pump.... kentj Modifications, Alterations and Updates 7 07-18-2008 01:15 AM
Hand Pump Water Fixture Brian T Problem Solving | Owners Helping Owners 1 05-28-2007 05:36 AM
