Have you seen this faucet? - Fiberglass RV
Old 05-22-2011, 04:29 AM   #1
jlbails's Avatar
Trailer: Boler 1977
I've run into a snafu with this faucet. I removed the copper water supply line to check for corrosion, and then took off the spout which attaches to the faucet base, just for fun. In an instant, the compression packing nut that attached the spout to the faucet was gone. You can see that the end of the spout was slightly flared. This nut was a specialty fitting made for the faucet. No plumbing supply store has it.
My dilemma is that I'd like to keep the original faucet as it worked fine, but the other problem is getting the correct sized fittings for the water supply line that was flared copper on both ends. I'd like to switch to a plastic line.
I could buy a new faucet, but then I've got to make the water supply line work on both ends. Has anyone encountered and solved this problem?
If you happen to have this faucet lying around, with the packing nut, I'd love to hear from you.
My Boler 77 had two faucets, a pump and city water supply; any creative solutions there? I can always fill a Coleman jug with water for inside, but it just isn't the same!
Thanks! Jamie
jlbails is offline   Reply With Quote
Old 05-22-2011, 01:48 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thanks! Jamie
Hi, Jamie!
You cracked me up with yor "just for fun" admission
How well I know what it is to give in to the urge to take things apart for the same inexplicable reason!
You might have better luck looking for plumbing parts for this application at an RV place- lots of trailer plumbing is weirdly specific to RV's.
Another possibility-
Some "local-type" hardware stores, mine included, have a wall of just-RV parts, including plumbing miscellanea.
Good luck!
Francesca
Faucet replacement Jim_B Plumbing | Systems and Fixtures 17 07-29-2012 10:03 PM
UHAUL FAUCET RICK H. Care and Feeding of Molded Fiberglass Trailers 2 02-11-2010 12:20 AM
Faucet help for a '75 Trillium Kimberly E Problem Solving | Owners Helping Owners 5 08-13-2009 05:23 AM
Looking for Sink Faucet georgia g Problem Solving | Owners Helping Owners 6 06-21-2009 07:03 PM
Faucet spits no more! Ruth C. Problem Solving | Owners Helping Owners 6 01-08-2006 01:53 PM
