help!! toilet troubles... - Fiberglass RV
Old 06-19-2013, 09:17 AM   #1
Trailer: 1978 Boler 17'
ontario
I just bought a 1978 Boler and I love it but the toilet leaks on the right side (left is you are not sitting ) . I can't even figure out how to remove the toilet to check for leaks...any suggestions....Please I am desperate to figure this out and have no clue at all!!
kelley m is offline   Reply With Quote
Old 06-19-2013, 06:49 PM   #2
Kelley, to FiberglassRV... we're glad you're here!
Lots of kind and helpful folks here, I'm sure you'll get the information you need.
First, do you know what BRAND of toilet is in your trailer? There's lots of good information in the Document Center, maybe you'll find exacly what you need there: Fiberglass RV - Document Center
Old 06-19-2013, 07:21 PM   #3
My 1978 Fiber Stream had a Thetford Aqua Magic III. It is bolted to the floor flange in exactly the same way your toilet at home is bolted. Due to the shape, look for a recess or indentation on each side. The bolts will be under a decorative plastic cover that looks like a very large acorn nut. It just pops off to reveal the bolt below it.
Old 06-19-2013, 07:35 PM   #4
papa-t's Avatar
Glade Valley, North Carolina
Welcome Kelly, Great advice above. Is it leaking without flushing on the left side or leaking from under the toilet? Mine did the same thing when I bought it and it just needed the incoming pipe to be tightened. Could need another wax seal if leaking from underneath; which is also easy. Hope your fix is also simple.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 06-19-2013, 10:11 PM   #5
Brian B-P's Avatar
The toilet should be mounted by a normal (like the one in your house) toilet flange, but instead of being at floor level it is on that raised platform; the platform is actually the top of the black waste tank. Some toilets have an extensive lower housing which hides the hold-down bolts. This may help understand how things are put together, but I agree with the other members' troublehsooting assistance... under what conditions does it leak, what model is the toilet...
Is this a rear-gaucho (B1700RGS or B1700RGH; bathroom opposite door), or a side-gaucho (B1700SGS or B1700SGH; bathroom in rear corner)? Does it have a water heater and shower (B1700RGH or B1700SGH; bathroom lined in moulded plastic or fiberglass)? This would help in explaining what is where.
Old 06-20-2013, 06:40 AM   #6
ShawnKK's Avatar
Kelly, we just got back from camping this past weekend and the same thing happen to me on the same side. I also have a 17 ft Boler. I havent had time to get into the problem yet but will this weekend. Mine only leaks when you flush.
Let me know what you come up with...
ShawnKK is offline   Reply With Quote
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
greece financial troubles john warren Jokes, Stories & Tall Tales 1 07-13-2012 04:11 PM
Troubles running off battery alone. byAndrewDavis Problem Solving | Owners Helping Owners 14 04-01-2011 09:08 AM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
Money troubles? Legacy Posts Jokes, Stories & Tall Tales 0 06-20-2003 12:07 PM
