I need help installing toilet. - Fiberglass RV
Old 01-18-2011, 02:59 PM   #1
Trailer: 2001 Scamp 13 ft
I have an '89 Scamp w/layout 6. I purchased a used Dometic Traveler M28-711 Sealand toilet. I want to install it so it has a water supply and a drainage system. I have the installation instructions but it doesn't have any dimensions other than "cut a 10 x 10 inch hole in the floor."
1. How long is the 3" waste nipple?
2. Where does Scamp route the line from the fresh water holding (pump) tank?
3. How is the vent routed?
I called the Scamp Parts Department but they were of little help. Pictures and advise would be most welcome. Thanks, EdD
Ed D is offline   Reply With Quote
Old 01-18-2011, 03:25 PM   #2
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
This might help
http://www.fiberglassrv.com/forums/f...let-42276.html
Old 01-18-2011, 03:51 PM   #3
Matt in SV's Avatar
Trailer: U-Haul VT16
There are a couple small photos on the Scamp store that may help with placement and routing
Scamp Trailers - Sealand
Regards,
Matt
Planning our next Escape!
Old 01-18-2011, 08:56 PM   #4
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
Matt... Up in your other post on this forum i posted something that may be of interest to you with a way casita converted these marine toilets with an add on plate inside to eliminates the marine discharge chute.
The following was pics of my installation in 2007 which may be of help to you.
Joe
http://www.fiberglassrv.com/forums/f...6-a-29059.html
Old 01-19-2011, 01:32 AM   #5
Matt in SV's Avatar
Thanks Joe, a link to that thread here:
Old 01-21-2011, 03:15 PM   #6
Thanks for the replies but what I was looking for was photos of an actual Scamp install. I'm wondering what route Scamp took to get the fresh water from the holding tank to the toilet. Also I need the lenth of the nipple Scamp used from the black water tank to the slider valve. Thanks again, Ed D
Old 01-21-2011, 05:24 PM   #7
What model 16' do you have ?
I have a 2009 16'SD with front bath.
Bill K
Old 01-21-2011, 07:23 PM   #8
Bill K
Bill, I have a 1989 16' with are for a front bath.
Ed D
Old 01-22-2011, 09:53 AM   #9
If it warms up a little (11° right now) I will take some pictures.
Bill K
Ed D
Old 01-22-2011, 02:51 PM   #10
Bill K
Thanks Bill, This is a spring project. Its hoving here in the mid teens. i'm tring to line up all the parts I need.
You bailed me out once before. You fixed my cube fridge at the Lake Erie Scamp Camp. At that time we had a 13' Scamp. This one ( 16') has the room in the front with a porta potty.
Thanks again, Ed D
Old 01-22-2011, 04:11 PM   #11
Ed if you go to the documents center and pull up the Scamp owners manual it has the water pipe lay out in it. Page 19? The water pipe runs all the way from the water input to around the outside edge of the trailer to the bathroom.
Old 01-22-2011, 07:49 PM   #12
Carol H, That answered one question THANKS, and I'm also happy to get a "paper" owners manual.
Thanks again Ed D
Old 01-25-2011, 07:41 AM   #13
Ed I may have finally got the pictures here.
These pictures are looking down.
The big pipe is the vent and goes out the side of the trailer.
The water line is the pink one but isn't much help.
Bill K
[IMG]file:///C:/DOCUME%7E1/WILLIA%7E1.KEL/LOCALS%7E1/Temp/moz-screenshot-3.png[/IMG]Click image for larger version
Name:	Water line to toilet.jpg
Thanks again, Ed D
Old 01-25-2011, 08:17 AM   #14
Bill- Great pictures. The pink water line was a help. I was planning to use tygon tubing but Scamp used PEX which I think would be studier then tygon. Next question, what is on the outside of the vent? I was thinking it had to go out the roof. I checked the Scamp parts store but they don't show a vent cover.
Thanks, Ed D
Old 01-25-2011, 09:53 AM   #15
Here is the vent cover.
Bill K
Name:	Toilet vent cover.jpg
Thanks, Ed D
Old 01-25-2011, 06:52 PM   #16
Bill
I guess I'll have to call Scamp. They don't show that cover in there parts store. I just wish there shipping wasn't so expensive. Is there any odor near that vent?
Ed D
Old 01-26-2011, 07:04 AM   #17
I tried looking elsewhere for that vent but could not find a picture.
I think the smell would depend on what chemical you put in the tank.
Bill K
Bill
Ed D
Old 01-26-2011, 07:26 AM   #18
Joe Z's Avatar
That side vent sure would be a solution but like the above poster said "Is there any odor near that vent?".... with a window open in the summer i wonder?..... I never seen a side vent before and wonder if that was a stock installation in that model?..... Going up thru the roof would take just about the same amount of effort as you still have to cut a hole in the fiberglass but at least up top the fumes would be "Up and Out".
The following picture of the tank shows the vent going "up"
Joe
Old 01-26-2011, 07:51 AM   #19
Joe,
To answer your question, yes it is a stock installation. The picture is of my 16' Scamp SD 2009 that I bought new.
Bill K
Joe
Old 01-26-2011, 09:12 AM   #20
Joe Z's Avatar
Thanks for the info bill.... Always try to keep up on things and they (scamp) know a heck of a lot more than me on trailer fabrication (and it's a 2009 model) so i guess it works just fine.
Joe
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
rv toilet Erwyn B Modifications, Alterations and Updates 1 09-02-2008 04:52 PM
What toilet paper do you use? RachelW Care and Feeding of Molded Fiberglass Trailers 28 08-13-2008 12:40 AM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
