Originally Posted by Peg Davis
Hi everyone,
My bathroom floor gets about an half inch of water when I pressure up the water system. Looks like it is coming from the connection of the shower hose to the shower faucet. Haven't seen it leak but have seen the connector make a spitting noise and a little bubbling after the shower head is turned off. When pressured up it seems to stop. What to do? Thanks in advance. It it a 2007 19ft standard scamp with the small side bathroom.
Unscrew the hose and look inside, the line end is flat and there should be a gasket or "O" ring to seal it.
If it all looks good then be sure it is tight before deciding to replace the line.
Another trick which I have had good luck with is to remove the hose and the showerhead then reverse the hose. This sometimes results in a better seal.
