Leaking below the bathroom - Page 3 - Fiberglass RV
Old 03-13-2014, 02:58 PM   #29
Trailer: 2014 Escape 21
Virginia
A short tailpiece of pipe that is threaded on only one end of the pipe is threaded into the tank bottom. Thread dope is applied to the threads before it is threaded tight into the tank bottom. You next dry fit you slip joint plumbing together and mark the joints. (Hard to see with Black ABS pipe.) When things are lined up to where you want them to be you then disassemble your plumbing clean the joints and glue it all back together.
With most glued drain plumbing, if you have a problem if can cut a piece of pipe out and join it back together with a slip joint coupling. With the Scamp drain the couplings are so tight together you don't have room to add a coupling.
If you look at the picture in post 17 you will see that when you try to unthread the pipe from the bottom of the tank the 90 will hit the frame rail. This is how it is done in a front bath since it is so tight a fit. In a side bath you may have room to unthread the tailpipe by removing the gate valve but I think you still may have the same clearance unthreading issue.
I think you and Carol may have side bath Scamps that's why we are not quite on the same line of thought. I have been dealing with Scamp FB plumbing most recently and on those trailers the pipe has to be cut to unthread the tank tailpiece.
Eddie
Old 03-13-2014, 05:35 PM   #30
Got it. THANKS EDDIE!
Old 03-13-2014, 06:43 PM   #31
Thanks Eddie for the explanation. Your right mine is a side bath and not only that put a previous owner made some changes under there so that my discharge pipe and gate valve are straight down - no turn in the pipe ... easy to remove no clearance issues.
Moisture Dripping from Below Rear Window fusedlight Problem Solving | Owners Helping Owners 8 08-17-2012 09:52 AM
Mystery space below closet in Trillium 4500 Gerhardt Problem Solving | Owners Helping Owners 11 07-24-2012 05:02 PM
Pulling a fiberglass trailer in temps below freezing Buck62 Problem Solving | Owners Helping Owners 6 12-06-2006 08:19 AM
Fibreglass at 40 below? Cam A General Chat 8 08-19-2006 10:26 PM
Below 0 F ... -18 C General Chat 0 12-31-1969 07:00 PM
» Trailer Showcase
Scamp
bippygma
Violet
Tara_B
