leaky potti - Fiberglass RV
Old 09-01-2012, 08:33 PM   #1
Saskatchewan
leaky potti
We bought a Dometic potti for what seemed like too much money. It leaks!!!!!!!!!! Blue fluid dripped from the drain cap - which had been ok earlier in the week. Fortunately we noticed and got it outside in a hurry.
Are these things bothered by temperature changes causing alterations in presure? If not that - then what do you think is the problem?
If it leaks when just sitting in the campground I hate to think what the floor would look like after a long drive! Just thinking about it is GROSS!
I sure hope someone has some helpful suggestions for us.
Hazel in Sk is offline   Reply With Quote
Old 09-01-2012, 09:52 PM   #2
dylanear's Avatar
Trailer: 2001 Scamp 13'
I have found that my Thetford did swell up with pressure in hot weather! But never leaked. I've recently "upgraded" to a Dometic, I sure hope that wasn't a mistake, the Dometic looks a lot nicer, but I've yet to use it.
I'd start by emptying and cleaning it, checking the drain cap seal and trying to get it to leak some water for testing. If you got some "debris" on that seal that could lead to leaking.
dylanear is offline   Reply With Quote
Old 09-01-2012, 09:57 PM   #3
dylanear's Avatar
The drain on mine is up high and on the end of a rotating tube. It would have to be very full and sloshing a lot to leak there. What model do you have?
I have the 2.6 gallon version of this one:
products - Dometic
Old 09-02-2012, 08:05 PM   #4
Saskatchewan
Hubby bought the smallest one as it wasn't likely to be used very much (just me - at night!). Right now it is put away somewhere so I can't check the model number.
Old 09-05-2012, 01:27 AM   #5
bomni's Avatar
Name: Matt and Lindsey
Trailer: 1972 Boler 1300
We just bought a small Dometic (smallest one at Canadian Tire) and it leaked the first time we used it (eww!!) We aren't 100% positive why, but it was either a.) too full and got bumped and it spilled over somehow where the flush valve is (my thought) or b.) the emptying cap wasn't properly tightened or got bumped and loosened (hubby's thought).
We took it apart (emptied & cleaned it) & out it back together assuring the emptying lid was super tight & that the two side latches were properly latched. We also assured it didn't get too full before we emptied it. This isn't specific, but it worked for us, no more leaks. I think ours is the smallest model available, if yours is too, they seem to fill up quickly even if only for nighttime use (for the wife), so we emptied every two days.
bomni is offline   Reply With Quote
Old 09-05-2012, 03:10 AM   #6
dylanear's Avatar
Do either of your Dometics look like the one pictured here? I'm curious if I need to be especially cautious. Mine will like get it's first use here and I'd be less than thrilled about a leak!
I think this one may actually be a rebranded Sealand that Dometic is selling.
Old 09-05-2012, 07:25 PM   #7
bomni's Avatar
Ours looks identical to this one (it isn't branded in the ad as Dometic & I was surprised when we got to Canadian tire & it was);
It is super basic with a canister at the bottom for emptying, no pipe for outflow. It didn't leak at all after the first time, I think ours wasn't put together right or was overfull.
Old 09-06-2012, 01:35 PM   #8
Lorene W's Avatar
Trailer: 1993 13 ft Scamp Custom Deluxe (a true 'Dream House'!)
I put a puppy "piddle pad" under my potti. Hopefully that would catch any drip that might occur especially during travel.
The directions for my potti said to put vaseline on all the gaskets.
So far, no disasters!
Lorene W is offline   Reply With Quote
Old 09-06-2012, 06:32 PM   #9
Saskatchewan
I have no idea what the instructions said that were with our potti - when we get something new hubby opens the box and tosses the filler and instructions! Ours is just like the picture bomni posted.
Old 09-09-2012, 12:09 PM   #10
Paul Chet's Avatar
Trailer: Vixen Motor Coach
Leaky or not ... WOW Dylan! That is a really beautiful throne you have set up there. If I remember correctly, you used wood and really sanded and painted so it's a near match to fiberglass. Anyway, just really appreciate your quality craftsmanship!
Paul Chet is offline   Reply With Quote
Old 09-09-2012, 05:40 PM   #11
dylanear's Avatar
Thanks! Given the amount of time I spend in this thing, I wanted a nice potty! Yep, it's carefully crafted wood, carefully sanded, and my painter did several (many?) layers of primer and sanding before putting on the top glossy coat. It's not as shiny as the fiberglass gel coat, not an exact match, but they look good together.
Need advise on a leaky slider Earl E. November Problem Solving | Owners Helping Owners 24 03-29-2012 03:57 PM
Leaky Windows?? 13 Scamp Evergreen Problem Solving | Owners Helping Owners 1 12-04-2010 08:53 AM
leaky wheel wells. michael robert Problem Solving | Owners Helping Owners 2 10-14-2008 04:51 PM
Leaky Windows and Vents Legacy Posts Problem Solving | Owners Helping Owners 5 04-22-2003 03:24 PM
Leaky Vents Legacy Posts Problem Solving | Owners Helping Owners 9 04-12-2003 12:13 PM
