Lets Talk Black Tanks - Fiberglass RV
Old 12-07-2013, 06:43 AM   #1
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
I'm in the market for a 16' camper with a bathroom and know nothing about black waste tanks.
So what can you put in them and what can't you? For instance can you you use those cottonell wet wipes or will they clog every thing up and how bad? I'm sure I already know the answer but I need to her from all of you with way more knowledge and experience than me.
Thanks!
Jason
If you think you are to small to make a difference just try sleeping with a mosquito - The Dally Lama
kirkman is offline   Reply With Quote
Old 12-07-2013, 07:05 AM   #2
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
I'm interested in what others might have to say about this - but my advice is to ONLY put things into your RV black tank that are intended for that purpose.
Reasons:
- Most residential toilets flush with a fairly large volume of water, RV toilets use minimum amounts.
- Residential septic systems use large diameter pipes with drop rates regulated by building codes. RV systems - both in your trailer and in the park, less so.
- Depending on your set-up and how frequently you give the system a good flush out, these things tend to sludge up anyway.
- Finally, when these systems do plug, cleaning out the backed up sewage can be a very nasty chore.
So, that's my $0.02
Steve_N_Janna is offline   Reply With Quote
Old 12-07-2013, 07:34 AM   #3
David Clinkenbeard's Avatar
Name: David & Sandy
Trailer: 2012 Escape 5.0
Cheap toilet paper that will dissolve, deodorizer, a wash wand to help you rinse your tank, and I put ice in while towing after dumping to keep the inside clean. I would also recommend keeping a small garden hose dedicated for washout and disposable rubber gloves on hand. Grey and black tanks are fairly easy to manage and you will likely be a pro in no time.
David Clinkenbeard is offline   Reply With Quote
Old 12-07-2013, 07:42 AM   #4
cpaharley2008's Avatar
Depends on if you want to have operating tank sensors. If you do, then only rv approved toilet tissue that dissolves should be used. If you do not want to use sensors, then anything that will flow out of that sized pipe would work.
Jim
Never in doubt, often wrong
Old 12-07-2013, 05:50 PM   #5
Trailer: UHaul
Massachusetts
The newly fashionable wet toilettes should not be put down any toilet - indoor or RV. They are too heavy and will clog.
Sharon D is offline   Reply With Quote
Old 12-07-2013, 08:29 PM   #6
Trailer: Fiber Stream
Increasingly clogged sewers attributed to popular ?flushable? wipes - Washington Post
Originally Posted by Washington Post
Sewage authorities generally recommend that people not flush products other than toilet paper.
I use those wipes, and have a trash can in the bathroom of the trailer to dispose of them.
BTW, Central and South American countries don't even put regular toilet paper in their toilets. Having a trash can next to the toilet is common there.
Old 12-07-2013, 09:28 PM   #7
Trailer: former class c now an egg hunter
A big no no to the cottonelle or any other wipes. Even the ones that state they are flushable. Oh...ahem....no tampons!
RV tp is expensive but something that breaks down fast is the best. We used Scott 1000. You can do the test to see if her brand breaks down. Put a section into a Tupperware / jar with some water. Shake it for 5-10 seconds. If it breaks into pieces you are good to go.
Anytime the pooper gets plugged up.....it's bad! Especially if you're the one that has to unclog it!
reetired is offline   Reply With Quote
Old 12-08-2013, 07:34 AM   #8
kirkman's Avatar
Thanks guys!!! That is what I thought.
I will try the Tupperware trick and see what happens.
And yes I am the one who will have to dig out the clog
Jason
Old 12-10-2013, 01:37 PM   #9
Mike Magee's Avatar
Trailer: Li'l Hauley
"Black Tanks": a crappy but important subject.
In my next trailer (whenever that comes to be), I would prefer a bathroom with shower but no black tank. Only a cassette toilet or porta potty. Since I don't have a good way to empty a black tank at my house, I can't use the toilet for the last day of travel back home. A cassette or porta can be easily emptied in my house toilet or any other toilet. Just a thought.
How to prepare Tofu
Step 2: grill some meat
Old 12-10-2013, 02:26 PM   #10
Name: David & Sandy
Hi Mike,
It's your choice. I'm guessing Escape will build you one without a toilet and black tank. Your likely in a minority and your resale will be hurt you compared to the factory cost of install. Later may prove impossible after the factory build. I can't understand why you don't have dump stations in your area. Oklahoma is a big camping state. There is information out there that points them out.
Old 12-10-2013, 02:59 PM   #11
Name: ginette & ron
Trailer: 2008 25RB 21 Bigfoot
Quebec
We like our soft toilet paper. That being the case we keep a small garbage can beside the toilet for all , ehmmm , products that do not come of of the body. We also use bio boosting additive after we flush the tank.
GiRo proud new owner 2008 bigfoot 21'with cargo pod and Jeep Grand Cherokee 2008 Diesel. Attached with a Pro Pride Hitch(Hensley design)
giro53 is offline   Reply With Quote
Old 12-10-2013, 03:44 PM   #12
Trailer: Escape 5.0 TA
W. Mass
Only Scott single ply in ours, even going with just that the darn sensors are wrong as often as not.
padlin00 is offline   Reply With Quote
Old 12-10-2013, 03:49 PM   #13
Oh poo, just make a tote. Cheap and then you won't need to worry about dumping the black OR gray when needed
Old 12-10-2013, 04:09 PM   #14
Or, you could hold it 'til you get home.
black/grey/fresh water tanks Saskstu Problem Solving | Owners Helping Owners 10 07-14-2012 08:11 AM
Black/Water Holding Tanks Don A Plumbing | Systems and Fixtures 2 09-30-2010 06:04 PM
help! clueless about dumping gray and black water tanks joy mccalla Care and Feeding of Molded Fiberglass Trailers 12 04-18-2010 08:13 PM
Lets talk about our summer plans! Mike Montville General Chat 17 03-30-2008 09:18 AM
How to know if Grey and Black tanks are full? Karen Fisch Plumbing | Systems and Fixtures 21 05-04-2006 09:24 PM
