looking for single fresh water faucet for 77 Trillium - Fiberglass RV
Old 04-06-2015, 05:23 PM   #1
South Carolina
Am having trouble finding a supply source for a new single faucet for our 77 Trillium. Any suggestions appreciated.
Dennis77 is offline   Reply With Quote
Old 04-07-2015, 10:02 AM   #2
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
In my 80 Trillium I replace by this one, I found in a Home Depot in Canada.
Blanco | Solid Spout Cold Water Faucet Stainless Steel | Home Depot Canada
Probably similar in your region.
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 04-07-2015, 10:17 AM   #3
Scamp also sells single faucets in their parts dept.
Old 04-07-2015, 10:30 AM   #4
Gilles's Avatar
Quebec
I had a similar to Scamp and I found too low...
Plumbing : Single Handle Faucet
Gilles
Bigfoot 15B17G.
Old 04-07-2015, 10:57 AM   #5
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
When you say single, are you looking for just a single handle, or for cold water only. I have one of the latter extra, brand new, for sale.
http://www.seapost.co.uk/whale-elega...ap-11197-p.asp
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 04-14-2015, 11:01 PM   #6
Trailer: Trillium 1300 - 1975
I replaced the faucet on our '75 1300 with a very inexpensive item from Ikea. Small in size, no issues to date, easy to install. Full details available if you'd like.
Greg
GKDee is offline   Reply With Quote
Old 04-15-2015, 04:07 AM   #7
Raz
Raz's Avatar
Vermont
I used one of these. There are numerous handle options and finishes. Raz
faucet
Old 04-17-2015, 06:13 PM   #8
any tips for removing the old faucet/pump - the PO installed a new one but left the old one…it looks pretty gross - we've got the screws out but it's not budging…not sure what we're going to find under it or how much repair we will have to do to the counter but I would like to get it out of there if I can…any thoughts?
littlemisspippy is offline   Reply With Quote
Old 04-17-2015, 06:18 PM   #9
Telling us what faucet/pump you have or a picture of it would be of considerable help.
On more than one occasion I have seen where prior owners have applies tons of sealer under the faucet. Most of the time they are just stuck and a metal putty knife and a tapping device (aka small hammer) usually frees them from the counter top.
Old 04-17-2015, 08:21 PM   #10
Thanks Bob - a little elbow grease and it came out - it was pretty corroded. As an aside, our sink has 2 taps - one for a water hook-up and a pump one for an on-board tank. I haven't tended to see 2 taps on most pics - is this common to have both set-ups - I'm thinking we should stick with one but my hubby thinks we should keep both. Again, any thoughts/comments?
Old 04-17-2015, 10:51 PM   #11
Trailer: 1975 Trillium 1300
My '75 trillium 1300 has two taps. One pump and one for hook up. Click image for larger version
Name:	ImageUploadedByFiberglass RV1429332634.619278.jpg
We are going to keep both although will most likely use the pump more often.
Lilly The Trilly - 1975 Trillium 1300
PrettylilTrilly is offline   Reply With Quote
Old 04-17-2015, 11:39 PM   #12
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Two faucets for two different sources, if it works for you, perfect.
Funny thing I just thought of. In thirty years of camping I've never once hooked up to city water, power and sewer yes but always used the house fresh water tank. Guess I'll have to try it sometime.
trillium
Need ideas replacing single faucet in Scamp!! stephbigs Plumbing | Systems and Fixtures 22 07-07-2013 01:43 PM
Single Faucet Randy D. Plumbing | Systems and Fixtures 11 08-06-2011 04:15 PM
Fresh Water Faucet? J Troxell Plumbing | Systems and Fixtures 10 02-21-2011 12:40 PM
Single Handle kitchen bar faucet Sheryl M Problem Solving | Owners Helping Owners 4 05-11-2008 08:56 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
