Meet the Toilet from Hell!!!! - Page 3 - Fiberglass RV
Old 02-19-2007, 10:08 AM   #29
Gina D.'s Avatar
West Coast USA
I leave my calipers at work.
Thanks. I am thinking a stop by at Walts RV in Fontana may be the best bet. No doubt they know exactly what I need, they have it in a little bin somewhere, and they won't charge me a dime for it.
They are like that. "Come back when you need to spend real money" is what they always say when I get little trinkets from them.
Old 02-19-2007, 11:06 AM   #30
Christi W's Avatar
Trailer: 1987 17 ft Burro
They have portapotties now in the cutest little hassock shape that doubles as a footstool
Christi W is offline   Reply With Quote
Old 02-19-2007, 11:58 AM   #31
Trailer: Trillium 4500
I may do that
This morning, my ribs ae bruised, my inner arms arm bruised, and my ego is flattened. I will NOT be defeated by a toilet!
BUT... just when you have a game plan (Pull the danged thing again and go down the hill to the evil Camping World..) Things got a little worse.
Yesterday, I was out there in a T-Shirt with the curtains closed to keep the heat down.
This morning, I wake up to a blanket of snow! To add insult to literal injury, all my stuff is outside beside the trailer, all my bins, the drying carpet, my tool box, AND.. the big table from the back. I am thinking it is sponging up every bit of water from the 4" of snow it's sitting in as I type. (I was going to store it anyway.. I guess no big loss until I go to sell the thing)
Since I have extension cords strung together to get power up the hill to the trailer (Don't worry, they get unplugged when I am not in attendence) I cannot work on it today for fear of being electrocuted.
I think the weather man is more evil than my toilet.
Where is my remote control?
I think I've heard a sad ole country song with this same theme. Just remember that you need to mention a couple of good ol' dogs in the refrain.
"My Toilet Done Me Wrong" blues.
David Schroeder is offline   Reply With Quote
Old 02-19-2007, 02:23 PM   #32
Gina D.'s Avatar
West Coast USA
I believe I have a solution for the nut loosening and tightening issue.
Hose clamp. Slip a hose clamp sized correctly onto the nut. Tighten. Use the screw tightening housing of the clamp as a place to push against, making the nut turn. One could push against this with a pair of long needle nose pliers.
No trying to grip the nut. I can get a screw driver shaft in there from the side, so getting the clamp on will not be a problem.
Now, if it stops snowing enough so I can plug the extension cord in for the cube heater, I am going to try it.
Old 02-19-2007, 04:13 PM   #33
I wish you luck! Based on the fading memory of my own struggles I would say that if you are successful I will mentally bow down and submit to your greater dexterity and ability to get your fingers in where mine had trouble. Based on the pictures I sent you my tool was a pair of sliplock pliers, moved, say, 2 degrees at a time.
When I need to do this again I will hitch up my little jigsaw and cut a rectangle out behind "La Toilette" and be done with it. Just this side of 8 minutes, I reckon. I have rethought the door idea. I will just make a wooden picture frame style and screw it in to hide the cutout kerf, using the cutout piece of fiberglass as part of the door. You want one too?
These valves do malfunction, but that is about the only thing that can malfunction in the thing. I say prepare for the worst, but I think you are there already.
Old 02-19-2007, 04:25 PM   #34
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
I'm sorry you are having such a hard time with this...... But you sure made my day, now I don't feel so bad about the defrosting of the freezer at work. Some things that should be soooo easy just aren't.
Larry&Carrie is offline   Reply With Quote
Old 02-19-2007, 05:02 PM   #35
Gina D.'s Avatar
West Coast USA
nothing is ever easy!
I have not tried the hose clamp due to the snow. I managed to lose several electrical items in the storm, including a 70 watt invertor, my holagen lamp, a clock and several adaptors for my 15 watt solar panel and misc stuff that is no big deal, but messy. (I wouldn't have left them outside otherwise. I was more cautious of theft than water)
I tarped the floor of the trailer, got as much snow off everything as I could and put the soaking stuff in the bathroom to drain, the bins on the floor and my dishes in the sink.
I hope my charger controller survived. It is supposed to be weather proof, so it most likely did.
My arms are so sore, I don't even want to think about getting in there until next week. This time with a pillow over the lid!
Old 02-19-2007, 06:56 PM   #36
Joe MacDonald's Avatar
Gina the fitting you show looks like a fitting for a standard sink connection (bathroom) using 1/4 or 3/8 plastic pipe. I thinks somebody's been in there before you.
PS don't use teflon on plastic. it'll make it worse
Old 02-19-2007, 06:58 PM   #37
DonInChatt's Avatar
Trailer: Cadet 1985 / 2006 Element
On the more universal theme of plumbing, I have often wondered why the important things that break and leak are always inaccessible next to the wall. Doesn't it make more sense to turn the toilet around so the vital stuff is facing out and accessible, and the occupant faces the wall?
DonInChatt is offline   Reply With Quote
Old 02-19-2007, 08:44 PM   #38
Trailer: 1985 17 ft Burro
Gina, I feel your pain...not physically but emotionally.
There is a website out there that contains more information than you ever wanted to know about every little thing to do with/in/around an RV. In this site there are many nuggets of information including your elusive plumbing fittings...
cut from site...
Repairs
Most older RV fresh water systems are plumbed using gray polybutylene tubing. Most connections are made using barbed connectors made of either gray plastic-like materials or brass and either aluminum or copper crimp rings. This plumbing will resemble the picture below. There have been a lot of claims that polybutylene plumbing breaks down and eventually leaks, usually at the connections. I spent some time researching these claims and I'm sad to say that there appears to be a pretty good case against the gray stuff. One thing is certain: they aren't making it anymore! It has been universally replaced by cross-linked polyethylene tubing in most newer RVs. Identified by it's white or red color, PEX is assumed to be safe and reliable. The connections are made either with Qest fittings or the familiar crimp rings as seen below.
Click for a bigger picture.
While scientific evidence is scarce, it is believed that oxidants in the public water supplies, such as chlorine, react with the polybutylene piping and acetyl fittings causing them to scale and flake and become brittle. Micro fractures result, and the basic structural integrity of the system is reduced. Thus, the system becomes weak and may fail without warning causing damage to the building structure and personal property. It is believed that other factors may also contribute to the failure of polybutylene systems, such as improper installation, but it is virtually impossible to detect installation problems throughout an entire system. In most cases it takes years for polybutylene systems to fail. While it may leak within a few years of installation, the majority of leaks start to occur in the 10-15 year time frame.
The address is http://www.ccis.com/home/mnemeth/plumbing/plumb.htm and a nice line drawing of many fittings can be found about 3/4 of the way down the loooooooonnnnng page.
Good luck!
D Shubel is offline   Reply With Quote
Old 02-19-2007, 09:14 PM   #39
Gina D.'s Avatar
West Coast USA
Thats great info.. thanks! Off to the helpful links it goes!
I THINK what I have is a quest fitting that has been jury rigged.
Old 02-20-2007, 01:53 PM   #40
Gina D.'s Avatar
West Coast USA
Walts RV to the rescue!
He knew exactly what I was talking about. His first comments was "I bet it froze". I told him nothing about the elevation and freezing conditions it was stored in, but he knew what happened anyway.
He walked over to a display, pulled out a Flare-it and hit the nail on the head for repair.
I haven't installed it, but it looks like it will work just fine.
More to follow... perhaps the Diablo will be put to sleep once and for all.
Old 02-21-2007, 08:09 AM   #41
Christi W's Avatar
Good morning Gina,
We're all waiting to hear that you have water in and water out!! Reading Per's comment reminded me of something. My grandparents has a 1/2 bath installed in a closet some time in the '50's. It required a very small toilet with almost zero clearance. Whoever installed it did put an access door behind the toilet Maybe for future access, or maybe he needed it to install in the first place. Most plumbers are contortionists, I think, it comes with the territory.
Keep us posted so we can celebrate!!
Old 02-21-2007, 10:47 PM   #42
Gina D.'s Avatar
West Coast USA
I haven't been able to do anything about it. My commute doesn't allow me to get home until after dark, and I barely have enough time to tend to the livestock, get myself dinner and rest a bit before I start it all over again.
Weekends are my only time during the winter. We are expecting another HUGE storm tomorrow, so I probably won't be able to attend to it on the weekend either.
I need to get a decent extension cord that is safe to use outside under less than stellar conditions.
I did manage to find a great deal on an Interstate group 24 megatron battery today. 60 bones! I think I paid close to 100 for my last one. (Camping World in "I need one NOW emergency)
Hopefully I can get it charged up and be able to run the furnace without the trailer plugged in. I might be able to get some work done then.
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
13 ft with toilet Schirah Wanted: Molded Fiberglass Travel Trailers 6 11-05-2007 11:23 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
A trip from Hell! Lisa F General Chat 34 04-11-2006 06:11 PM
