Mega-Disaster: Leak under rear bed - Fiberglass RV
Old 11-23-2015, 04:37 AM   #1
Trailer: Casita SD17
New Jersey
There is a leak under the rear bed, which unfortunately has a ton of stuff on top of it. I cleaned it up, only to discover a new pool of water. I think it might be leaking when I flush the toilet.
I took this week off from work to prep it for winter living, I guess I will be doing plumbing instead.
whoot is offline   Reply With Quote
Old 11-23-2015, 05:35 AM   #2
I would first pull off that wood piece as there is a water line under it. Should be just two screws
Old 11-23-2015, 06:11 AM   #3
Ian G.'s Avatar
Check all the connections to your fresh water tank, since it is located under the dinette seat if a fitting is loose or leaking that could be the problem.
Old 11-23-2015, 06:59 AM   #4
Dudley's Avatar
Trailer: 1998 Casita 17 SD
The 2 seats are fairly easy to pull out as is the rear slant board. then you have a good look at everything. The converter on the streetside is the hardest thing but it rotates and gets shoved through the hole. I don't think the leak will be tied to you flushing other than the water pump is under there. Its a long way from the bathroom. Check every connection and get a 1/2 pex crimper and rings (hose clamps will not work for long). Check the water tank connections as well. You will need a #2 square drive screwdriver for the screws (#2 Robertson for us Canucks). There are a splices and connections in the plumbing and my guess is when you flush , the pump kicks in and either the pump is leaking or the increase of pressure is causing a leak at a pex joint.
Does the pump cycle between water use, Should just give a quick 1 second burp every 10 minutes or so(at least mine does) any more than that, you have a leak in the system somewhere.
Good luck
Old 11-23-2015, 11:23 AM   #5
IllAnnoy
Cheer-up, what you have is a maintenance issue.
This is a Mega-Disaster...
Old 11-23-2015, 12:25 PM   #6
BatDude's Avatar
So floyd,
They left the beer bottle in the freezer too long to cool and Boom?
That is a mega-disaster for true. AAA service would just need a broom and large dump truck for clean up.
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Scamping, painting and mentoring students
BatDude is offline   Reply With Quote
Old 11-23-2015, 02:11 PM   #7
IllAnnoy
Originally Posted by BatDude View Post
So floyd,
That was from a previous thread.
I didn't mean to hijack this thread, so further discussion of it should maybe continue here...
The loss of my scamp
Old 11-23-2015, 07:40 PM   #8
New Jersey
Thank you for all the support! My neighbor found a loose connection where all the water lines are (to the left of the circuit-breaker), he saw a drop of water come from the connection he tightened, so that may have been it.
A person at the campground I am at, told me several months ago, that I would not need the 40-50 psi water-pressure lock, and that if I used it, I wouldn't be able to take a shower. So I never connected it. Now that the campground is mostly empty, all the smart people went south, I think my Casita might be getting more water pressure than normal.
Between the loose fitting and extra water-pressure, that may explain the leak. I think it was a very slow leak that was there for a while, maybe a month or more.
Now I have a water-sensor inside the water compartment, so if it starts leaking, it will make some noise. I will also check it frequently, especially after running water.
Thanks!
Old 11-23-2015, 07:54 PM   #9
Originally Posted by whoot View Post
A person at the campground I am at, told me several months ago, that I would not need the 40-50 psi water-pressure lock, and that if I used it, I wouldn't be able to take a shower. ...
And a member of this forum perhaps?
Anyway, glad it was an easy fix. Now use your pressure regulator!
Old 11-23-2015, 08:25 PM   #10
IllAnnoy
Amen! If you don't have one, get the brass one, it works great for us and we have showered with it in place for 11 years.
Old 11-24-2015, 08:09 AM   #11
Thanks!
Just to add, that advise ranks right up there with looking for propane leaks with a match...... and it's the first time, in over 40 years of RV'ing , that I have ever heard it.
It's a "Pressure Regulator" and it limits pressure, not volume and, if local pressure happens to be below the set value, it will just pass through the regulator. I'd bet that the source either has/had a bad regulator, or they need a shower head cleaning.....
Water Line pressure can range up to more than 150 PSI, and some campgrounds will intentionally let it run that high to accommodate undersize supply lines to multiple users. That's enough to almost guarantee a leak.
BTW: Always put the regulator at the faucet end of the hose to protect the hose from high pressure as well.
Old 11-24-2015, 11:28 AM   #12
WendyW's Avatar
In this case Whoot really did have a leak, but I've also had water under the rear bed that turned out to be condensation. Apparently the mattress bottom attracts condensation, and on another forum I read that the solution was a piece of rug-like marine fabric to be placed under the mattress. I solved my problem (after determining that nothing was leaking) with a space heater and running the fan "out."
WendyW is offline   Reply With Quote
Old 11-25-2015, 09:09 AM   #13
TheWanderers's Avatar
Trailer: 1988 Bigfoot Fiver
Kentucky
OMG, I never knew this either...
Thanks!
Very good advice about the pressure regulator. Thanx!
"Not all those who wander are lost." J.R.R. Tolkien
TheWanderers is offline   Reply With Quote
Are you ready for a disaster Tom McRae General Chat 36 04-22-2012 10:26 AM
Water Leak -Puddle under rear window cushion Dave Storey Problem Solving | Owners Helping Owners 14 05-06-2011 11:56 AM
Earthquake Disaster Survival Frederick L. Simson General Chat 6 08-11-2008 04:33 PM
OREGON 2006: Disaster Avoidance for Newbies Frederick L. Simson Rallies, Get-togethers, Molded Meets (Archive) 0 06-27-2006 04:51 PM
Disaster strikes Legacy Posts General Chat 35 08-21-2003 11:16 AM
