Need help Installing a water pump on scamp 1979 13' - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Plumbing | Systems and Fixtures
Click Here to Login
Old 04-20-2015, 09:12 PM   #1
I am installing a Shurflo WP on my scamp.... Where do I supposed to connect the black and red wire? Yea I know that red is power and black ground.... The thing is that I don't see the wire where is supposed to be connected..... help please.....
Thanks.
juanka is offline   Reply With Quote
Old 04-21-2015, 05:31 AM   #2
If you are replacing a pump the wire should be there close at hand, and you should have a manual switch to turn the pump off and on. The wires might not be black and red ! If you have never had an electric pump you should run a new line with a switch.
Old 04-21-2015, 05:40 AM   #3
Thanks.
Do you know if this year was design with WP?
Do any one have the wiring diagram for this model?
Thanks.
Old 04-21-2015, 06:32 AM   #4
Trailer: Class A Motorhome
You will need both an on/off switch as well as a fused 12 VDC power lead for your water pump. It sounds like you need some outside help before you run into additional problems. And yes, a pump with a pressure switch also has to have it's own on/off switch.
Need help with a 1979 17' Boler Water Heater J W Moody Problem Solving | Owners Helping Owners 11 11-27-2015 05:38 PM
I need help installing toilet. Ed D Plumbing | Systems and Fixtures 39 05-08-2011 10:46 AM
New manual water pump needed, need suggestions Michael Collins Modifications, Alterations and Updates 12 03-16-2010 06:03 AM
Help! Installing hot water heater Robert Johans Problem Solving | Owners Helping Owners 6 07-16-2009 08:22 AM
Installing Water Pump and Faucet with Switch Patrick M. Modifications, Alterations and Updates 28 05-04-2007 06:18 AM
