Need plumbing advice - Fiberglass RV
Old 06-03-2012, 06:24 PM   #1
Steve_N_Janna's Avatar
Name: Steve and Janna
Trailer: '02 Scamp 13
I will soon be installing a toilet and in our Scamp 13 and in the interest of avoiding another hole in the shell am considering venting it through the floor. I would plumb the vent by vertically running it a few feet above the highest point in the toilet and then do a "U" turnaround and run it down through the floor. I'll cap it with a screen to keep insects out.
I realize this is an unorthodox approach. AM I MAKING A MISTAKE???
I would appreciate any thoughts or comments. Thanks.
Steve_N_Janna is offline   Reply With Quote
Old 06-03-2012, 06:59 PM   #2
Trailer: 2014 Escape 21
Virginia
The gasses will want to rise, if you loop the vent down the gasses will collect in your holding tank and when you flush the gasses will come back through the comode opening. Scamp holding tanks are normally vented through the side of the trailer through a small louvered opening.
Eddie
Eddie Longest is online now   Reply With Quote
Old 06-03-2012, 07:39 PM   #3
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Vent
If your going to run it up a few feet, why not just take it through the roof.
A vent cap and your done. Why make it complicated?
Who wants to smell crap coming from under the trailer.:
Old 06-03-2012, 07:54 PM   #4
Eddie
This is a link that shows what Eddie mentioned. Norm posted this back in February. Slick idea for flushing the black water tank. Better than sticking a hose through the window and down to the toilet IMHO. On my Scamp the vent pipe comes out of the top of the black water tank ... up and out to the side of the trailer.
Clever Scamp Mods - Black Tank Flush Mod
Old 06-03-2012, 10:48 PM   #5
Trailer: Fiber Stream
YES you are making a mistake
Originally Posted by Steve_N_Janna View Post
I ... am considering venting it through the floor. I would plumb the vent by vertically running it a few feet above the highest point in the toilet and then do a "U" turnaround and run it down through the floor...
The end result will be as if you had not vented the toilet at all after all that plumbing construction.
The gasses in the tank will vent to the highest opening which will be into the trailer every time you flush.
Old 06-04-2012, 06:32 AM   #6
I appreciate everyone's' advice !!!
Hmmm...I think I'll scrap that plan!
Old 06-04-2012, 07:23 AM   #7
Roy in TO's Avatar
I was going to suggest using a "cheater" vent like in a house, thinking that the purpose of the vent was to allow air into the plumbing pipes for the flush and draining of the tank.
Old 06-04-2012, 10:29 AM   #8
Roy, what is a cheater vent (one way valve perhaps?)
This sounds like something I might consider for my sink, which I plan to drain into a portable tote tank.
Thanks!
Old 06-04-2012, 10:45 AM   #9
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Air Admittance Valves from Oatey | The Home Depot - Model 39018
Old 06-04-2012, 06:25 PM   #10
Thank you, Thank you!! (from Steve's wife)
Old 06-04-2012, 07:07 PM   #11
LOL I suspect the easiest would be to just put the little vent in the side as Scamp does - I have never had any leak issues with it.
Old 06-04-2012, 07:47 PM   #12
Neither have I, nor smells, but I do use chemicals.
Plumbing question Lainey Plumbing | Systems and Fixtures 8 08-10-2008 09:18 AM
Plumbing traps? Roy in TO Plumbing | Systems and Fixtures 4 07-08-2008 10:12 AM
plumbing help Phil Underwood Plumbing | Systems and Fixtures 5 04-08-2008 06:16 PM
propane plumbing Paul and Libby Smith Care and Feeding of Molded Fiberglass Trailers 14 11-27-2007 06:02 PM
plumbing plumbing plumbing..... Herb P Plumbing | Systems and Fixtures 6 06-17-2007 06:01 PM
