New Anode-Tape or No Tape - Fiberglass RV
Old 11-11-2015, 09:34 PM   #1
Northern California
Hello, bought an 98 Scamp trailer recently and have been busy doing a bit of this and a bit of that.
It is getting chilly here in the Sierra Nevada's now, so I tried to winterize the trailer today. I pulled the drain plug(Anode) for the hot water heater. The shaft for the plug was only about 1/8 inch thick so I assume it was an old anode that was completely gone? Anyway I got another Anode and put it in (actually it did not thread all the way in as the threads are longer than the old one, but I read in another thread that this is ok). My question is do I need to put teflon tape on the threads? or will the plug be fine without putting tape on the threads?
HAPPYSCAMPER76 is offline   Reply With Quote
Old 11-11-2015, 09:46 PM   #2
Cathi's Avatar
POBox 1267, Denison, Texas
You need Teflon tape or you may have a heck of a time getting it out of there later.
Old 11-12-2015, 05:37 AM   #3
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Chances are that if you remove the anode periodically to inspect it (spring and fall) you will never have a problem getting it out even without tape or pipe thread sealant. If you do use Teflon tape or a non-toxic pipe thread sealant (typically used to prevent leaks), you should test for continuity between the tank and the plug using an electrical meter. Without continuity, the anode will not protect the tank. That being said, I have used both over several years of RVing and check for continuity every time, but have never had any incident when the meter indicated lack of continuity.
Old 11-12-2015, 05:40 AM   #4
Tape. Cheap insurance.
Old 11-12-2015, 08:29 AM   #5
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Donna D... Former President Richard M Nixon thought so!!! I was told by my RVTech not to use it.
Old 11-12-2015, 09:43 AM   #6
What reason did he give? Didn't he have any on hand?
Old 11-12-2015, 10:16 AM   #7
David Tilston's Avatar
A sacrificial anode has to have electrical continuity to work. That said, I have a hard time seeing how the tape would not be pierced in several places when tightening the plug. As mentioned, a continuity check would be good.
Old 11-12-2015, 10:49 AM   #8
Trailer: Escape
My trailer came this year from the Escape factory with tape on the threads, so I plan to continue that practice. There must have been continuity as I saw some deterioration of the anode.
Bill Dornbush
http://dornbush.net
hwdornbush is offline   Reply With Quote
Old 11-12-2015, 11:28 AM   #9
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Or, you can use "NEVR-SEEZE" on the threads.
Old 11-12-2015, 12:23 PM   #10
CPW
CPW's Avatar
Or you can go to Home Depot, Lowe's, Menard's, and probably Canadian Tire and buy pipe joint compound that is rated for potable water. The advantage of using compound is that it does not leave pieces in the threads that you will want to pick out before reinstalling the anode as Teflon tape does.
As I said in a previous post, I check continuity every time I have reinstalled the anode in any trailer I have owned, and have NEVER had either tape or compound interfere with continuity.
Old 11-12-2015, 01:55 PM   #11
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I always tape stuff like that!
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 11-12-2015, 04:30 PM   #12
sokhapkin's Avatar
SW Florida
When metal is threaded to metal, it must be taped or the threading will leak.
Sergey
www.callwithus.com
Old 11-12-2015, 04:41 PM   #13
Alf S.'s Avatar
Frank
Hi: frank_a... Nixon taped everything too!!!
Old 11-12-2015, 05:47 PM   #14
It is VERY possible your Scamp's hot heater never had an Anode rod.
If its an Atwood water heater they do not use or need Anodes. The tank of the Atwood is made of aluminium and thus not subject to the same corrosion issues that Suburban water heater is.
Edit to add: Atwood btw normally uses plastic plugs from the factory so no nylon tape is needed.
Suburban hot water heater anode difficult to install Steve M. Problem Solving | Owners Helping Owners 7 05-25-2009 07:22 PM
Anode Rod for heater.. Christi V. Care and Feeding of Molded Fiberglass Trailers 4 04-20-2008 09:25 AM
anode rod JHJohnson Problem Solving | Owners Helping Owners 2 08-07-2007 07:59 PM
An ideal anode removal tool Legacy Posts Modifications, Alterations and Updates 4 10-28-2002 01:38 PM
Anode Rod winterizing question? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-18-2002 09:03 PM
» Trailer Showcase
Scampy
Jon in AZ
Tidbit
Loyce
