New Toilet - Fiberglass RV
Old 12-29-2011, 07:17 AM   #1
tncruzin's Avatar
Trailer: 1978 Scamp 19' 5th wheel
New Toilet
Rookie here guys so cut me some slack! I have a 19' fifth wheel Scamp. I am planning to install a permanat toilet. I'm needing guidance on the installation. I know the basics of what is needed but am not certain on the details. Things like which floor flange to use, the best way to connect to the black water tank, adding a drain to the tank, etc. The toilet I'm adding is the Thetford Aqua-Magic V. Any help in the form of pointers or diagrams would be appreciated.
tncruzin is offline   Reply With Quote
Old 12-29-2011, 10:32 AM   #2
Sorry cant help you as I thought the 19' had the same toilet set up as the 16' where the blackwater tank was inside the bathroom and attached to the toliet. Like this Sealand Black Tank For Toilet
I kind of like it that way as its one less outside tank to worry about freezing when camping in cold weather.
Check the Scamp Parts Department at the link above for all the flange parts etc you will need.
Old 12-29-2011, 11:24 AM   #3
tncruzin's Avatar
Does this tank drain through the floor to the outside or do you have to remove it through the door to empty??
Kenny Lane
"Character is doing the right thing, even when no one is looking."
Old 12-29-2011, 11:36 AM   #4
It drains through the floor using the same type of drainage system as your grey water tank uses. Its a 3" sewer termination valve. All parts needed at Scamps parts department also its all pretty standard RV fittings so you should be able to obtain at any RV supply store.
Old 12-29-2011, 11:40 AM   #5
tncruzin's Avatar
Thanks Carol....I'll look into it!
Kenny Lane
Old 01-02-2012, 10:58 AM   #6
Larry C Hanson's Avatar
RV Toilet Alternative
Hello,
I think the easiest installation would be a boat type composting toilet.
I have been using one for years and they work fine. Exhaust fan uses
about 2 amp hours / 12 V DC per day. No black water tank to empty.
GOOGLE
Nature's Head
Airhead
Good Luck, Larry H
Old 01-07-2012, 07:06 AM   #7
kirkman's Avatar
Trailer: 2007 Eggcamper & Homemade Tear Drop
Here's the link. to natures head.
Nature's Head Composting Toilets - The environmentally sustainable waterless toilet for Your Boat, RV, Cabin, Big Rig, Barn, Workshop, or Yurt!
kirkman is offline   Reply With Quote
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
rv toilet Erwyn B Modifications, Alterations and Updates 1 09-02-2008 04:52 PM
13 ft with toilet Schirah Wanted: Molded Fiberglass Travel Trailers 6 11-05-2007 11:23 PM
Campground Toilet Roy Bakehorn Jokes, Stories & Tall Tales 1 07-31-2007 11:34 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
