plastic knob to drain water tank rotted again - Fiberglass RV
Old 09-28-2008, 06:17 PM   #1
Karalyn's Avatar
Trailer: Eggless for now but looking. currently own Amerilite 21 ft
I had the neighbor install a new plastic outside knob a couple of years ago and it worked great. This is the knob/outside faucet thingie to drain the holding tank when needing water for boondocking. However this yr, the plastic is already hard to turn and is breaking the knob off again. The neighbor has moved, and I need a perminent solution this time.
Do you all just replace that knob every 2 yrs??
Is ther some type of a metal knob solution???
This is the worst thing I have found in my Scamp and Casita so far. These knobs just seem to break when turning.
thanks
Karalyn
Old 09-30-2008, 07:24 AM   #2
Steve Hilby's Avatar
Trailer: Compact Jr
How about adapting some kind of household plumbing globe or gate valve?
Maybe something like this?
http://www.acehardware.com/product/index.j...rentPage=family
Or this?
Or these?
http://www.acehardware.com/family/index.js...2631273.2631382
Steve Hilby is offline   Reply With Quote
Old 09-30-2008, 02:38 PM   #3
pjanits's Avatar
Trailer: 17 ft 1986 Burro
My Burro has something like this mounted to a aluminum plate that screws to the floor.
http://www.hardwareworld.com/F322p-38-Bras...ck-pN7NTW3.aspx
Also known as radiator drain cocks the link is just for reference I've seen them for $2.00 check the auto parts places too.
See if you can invent something to work for you.
Old 09-30-2008, 04:44 PM   #4
Trailer: 94 Casita 16 ft
I'd start with an NPT (national pipe thread) / barb connector to go on the hose that's connected to the water tank.
picture found here
On the outside, I'd just use a standard garden hose bib. You should be able to find the NPT/barb connector that will fit both. After that, you can rivet the brass hose bib to the side of the camper. The only fear I would have is that if it caught on something, the fiberglass would break before it did.
Paul from NWOnt is offline   Reply With Quote
Old 09-30-2008, 08:14 PM   #5
Karalyn's Avatar
this is the thing that is rotting out again. I can not get the picture to show up, but maybe by seeing this you will understand better what I am looking to replace.
Camco Manufacturing Inc. 22223 RV Drain Valve 3/8" or 1/2" Barb with Flange
See larger image
Share your own customer images
Other products by Camco
No customer reviews yet. Be the first.
List Price: $4.99
Price: $4.19
You Save: $0.80 (16%)
In Stock.
Ships from and sold by Mobile-Mart.
3 used & new available from $3.99
Product Features
* Easily drain your RV fresh water tank
* Graduated for use with 1/2" or 3/4" vinyl tubing
* Durable plastic
* Valve with flange
Karalyn
Old 09-30-2008, 09:45 PM   #6
I know exactly what doohickey you're referring to, I had to replace mine this summer as well. The picture that I directed you to is just an adapter that would allow you to use something completely different to replace the plastic thing.
You'll still have to drill out the rivets, and remove the plastic one. Then you'll need to disconnect the plastic line from inside to make it easier to work on.
Hang on.... I'll see if I can get pics to explain. Back later.
Old 09-30-2008, 09:56 PM   #7
Alright, let's see if I can make this work with images pilfered from the net...
The idea I have is to replace this;
with one of these (or similar)
connected to the line from the water tank by using this adapter
It would certainly outlast any little plastic bit.
Old 10-01-2008, 02:26 AM   #8
Karalyn,
The photo in Paul's post is probably what you have. If that's the case, you should service the valve at least annually.
To do that, pull up on the handle with a pair of pliers (cushion with a piece of cloth) and the shaft whould pull right out. Coat the shaft with petroleum jelly (Vaseline) and re-insert it.
Morgan is offline   Reply With Quote
Old 10-01-2008, 06:50 AM   #9
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: Morgan... The plastic or whatever the're made of becomes old and brittle...Kinda like ME!!! I crushed mine with the pliers so just had to spin on another. They really are cheap.!!!
Old 10-01-2008, 10:31 AM   #10
Mine was held in with a hoseclamp, so a little surgery was required. If I only get a couple of years out of the replacement, then I'll go with the setup I described above, and right beside it I'll have another tap for pressurized water. Then again, I may do something else altogether depending on my mood at the time.
Back to the original problem: You'll likely have to drill out the existing rivets if you are going to use another of those plastic valves. Since I don't know how mechanical you are, I'll just say that this is a simple little project that is only frustrating because of the tight quarters that may be involved. I'd try to tackle it myself first, as long as you aren't using a crowbar to pry on things you can't make them any worse.
Old 10-02-2008, 05:12 PM   #11
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
Mine just rotted also! I'll have to order a new one.
BOBSMITH is offline   Reply With Quote
Old 10-03-2008, 10:22 PM   #12
Ours became brittle and fragile also. After installing a new one, I then cut the plastic drain line and inserted a plastic ball valve using 2 of the barbed fittings. The Casita has a locked access door in just the right location for access to the ball valve. Now we simple leave the replaced valve open all the time and control the flow with the ball valve. This will also prevent some mischievous youngster from draining the water by "accident", and even if the exposed valve becomes damaged our water system will still be functional.
Kurt & Ann K.
Old 10-04-2008, 09:56 AM   #13
Trailer: 1998 17 ft Casita Spirit Deluxe / Red F150 X-Cab
I have the same problem: one half the handle broke off last year and the other half followed this year. I'm reading the variou solutions to the problem with interest. Thanks for bringing it up, Karalyn.
Lisa M. is offline   Reply With Quote
Old 10-06-2008, 12:01 PM   #14
Don't know what the original looks like, but could you install a brass valve in its place?
Brass Drain Valve
Trillium water tank drain John Perry Problem Solving | Owners Helping Owners 5 10-15-2007 08:59 PM
Water tank drain Lee Hillsgrove Problem Solving | Owners Helping Owners 3 07-01-2007 08:41 PM
Gray Tank Drain Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 06-08-2003 06:50 AM
