Propane fitting end cap - Fiberglass RV
Old 04-02-2015, 10:41 AM   #1
khoa l's Avatar
Trailer: 76 Boler 13 ft
HiClick image for larger version
Name:	<a title=propane.jpg Views: 17 Size: 58.8 KB ID: 82129" style="margin: 2px" />
I disconnected by old gravity heater and would like to close/cap off the valve. I can't seem to find for the life of me the correct size.
I measured the inside dia.and it come to 19/32
I've tried both a 3/8 and a 1/2 and either its too big or too small. Do they make a 19/32?
khoa l is offline   Reply With Quote
Old 04-02-2015, 10:55 AM   #2
Tahe the picture and the facts to a furnace repairman and I bet they have just what you need.
Old 04-02-2015, 11:08 AM   #3
khoa l's Avatar
Thanks, I then called the local propane co. and they are confident they will have somethign.
Old 04-02-2015, 11:51 AM   #4
The photo is showing a flare fitting. The seal is made when the flare in the copper tube is compressed into the new fitting. Just matching threads will not solve your problem. A good propane supplier can help. Can you follow the tube to another connection and seal it with a plug ?
Old 04-02-2015, 12:42 PM   #5
There are various fittings available to easily plug that, Flare one end, pipe thread other. Also there is a cap for flare fittings. Just be sure to check for leaks when you're done with soapy water. I can take a photo of the fittings if you need but I'll have to dump a couple cans and dig through the contents
Old 04-03-2015, 09:15 AM   #6
sparky1's Avatar
Trailer: Casita patriot deluxe (sold)
Virginia
ace hardware carry's all kind of flair pieces--to cap this off.
sparky1 is offline   Reply With Quote
Old 04-03-2015, 09:21 AM   #7
khoa l's Avatar
Got the fitting from a local propane place. All good. Feel safe now. I think it had a small leak when it was originally hooked up to the gravity furnace which is no longer in use so decided to pull it out and cap it.
I tested the connection with soap and water and no bubbles.
propane
End Cap for sewer hose storage tube Steve Hammel Plumbing | Systems and Fixtures 5 06-24-2013 06:53 PM
Snap cap/Button cap question Kevin K Problem Solving | Owners Helping Owners 5 06-19-2012 11:50 AM
Grease Leaking from Metal End Cap on 2005 Scamp 5th Wheel jcellis54 Towing, Hitching, Axles and Running Gear 11 03-09-2012 01:49 AM
cap- off propane gasline T connector? Ken Ford Problem Solving | Owners Helping Owners 4 05-29-2008 08:25 PM
propane cap carole sullivan Problem Solving | Owners Helping Owners 5 05-11-2008 08:13 PM
