Proper maintenance of water tank and water lines - Page 2 - Fiberglass RV
Old 09-18-2015, 06:22 PM   #21
EllPea in CA's Avatar
Trailer: 1989 Lil Bigfoot
CA
Originally Posted by Borrego Dave View Post
We're tied at 1 to 1 with typos .
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 09-18-2015, 06:26 PM   #22
CA
Originally Posted by Uplander View Post
Reply #3 by P. Raz has the correct procedure for proper safe sanitizing of RV water systems. If you do this on a regular schedule you will avoid water system problems. I also use a water filter when hooked-up to a campground water source. It is a simple method....use it!
Ask the same question on the irv2.com website and you will get the same answer from veteran RV owners.
OK... now the only thing I wasn't sure about in Reply #3 is whether after sanitizing I should leave the tank empty, or fill it up again?
Best,
EllPea in CA
Old 09-18-2015, 07:40 PM   #23
Stagnate water should be avoided.
So... empty unless the water will be used soon. If the tank does sit with water in it for many weeks or a few months, empty and refill with fresh water before use.
Old 09-18-2015, 09:46 PM   #24
CA
I understand that we should not use water that has been in the tank for a long time. I would always drain and put in fresh before use.
My question is: is it better maintenance for the tank and water lines to be stored empty or with water in them? It seems to me that an empty but damp tank is more likely to grow gunk... but I could be wrong!
Best,
EllPea in CA
Old 09-18-2015, 10:02 PM   #25
Take a look at your state emergency preparedness site for possible earthquake. I keep five five-gallon containers of water on my property and change the water every six months, adding a few drops of unscented bleach with each change.
You should find guidelines there.
New water tank and exterior tank fill "door" Treedles Modifications, Alterations and Updates 10 10-11-2013 10:38 AM
Proper black tank venting on Scamp side bath Ryan P R Plumbing | Systems and Fixtures 12 03-30-2013 07:38 PM
Lines for Fresh Water Tank Ryan P R Plumbing | Systems and Fixtures 6 07-08-2012 12:20 AM
water tank and lines 1976 scamp jimtesla Problem Solving | Owners Helping Owners 2 08-03-2010 11:43 PM
The importance of proper weight distribution Legacy Posts Jokes, Stories & Tall Tales 6 03-21-2003 07:48 AM
