Questions about installing an outside shower - Fiberglass RV
Old 04-17-2016, 12:31 PM   #1
Trailer: plan on buying lil snoozy
Massachusetts
Is there an advantage to having an outside shower installed on the drivers side vs the rear?
In the case of the Lil Snoozy, how high is the shower when installed on the side - where is it mounted? What is the approximate length of the shower head/hose? Is the total height at least 6 1/2 or 7 feet? Does it feed from both the hot and cold connections?
Ransom is offline   Reply With Quote
Old 04-17-2016, 01:46 PM   #2
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Lil Snoozy is very amendable to what the buyer wants. They will install whatever you want within reason. Call the factory and they can help you.
Old 04-17-2016, 02:04 PM   #3
Don W3NDT's Avatar
My Lil Snoozy has the shower on the back below the A/C unit just below counter level. The hot and cold water are tapped off the sink supply. The hose is about 4' long and you can hold it over your head. I like the location because you can stand on the step, wash your feet and step inside the trailer.
Don
Don W3NDT is offline   Reply With Quote
Old 04-17-2016, 08:25 PM   #4
Massachusetts
Don
It seems like you would bump your head on the air conditioner. I am 6' 2 1/2" and am thinking that with just around 4 feet of hose and the need to step away from the air conditioner, I wouldn't be able to get the shower head at least 6 to 8 inches above my head...?
Perhaps the shower unit could be installed a bit higher (closer to bottom of air conditioner) maybe not for loss of structural strength...
Or, a longer shower hose?
But I see how having the shower close to the trailer entrance keeps you from getting your feet dirty after the shower.
Inside vs Outside shower? aimeelightsey General Chat 47 03-05-2016 07:39 AM
adding an outside shower?? Peggy Modifications, Alterations and Updates 1 08-01-2011 11:25 PM
outside shower cpaharley2008 Plumbing | Systems and Fixtures 5 04-12-2011 06:07 PM
Installing a shower in 13ft. bonnie w General Chat 4 08-13-2008 02:07 AM
Installing a Shower Taylor Problem Solving | Owners Helping Owners 5 02-12-2007 09:21 PM
