Regulator and hoses - Fiberglass RV
Old 03-05-2012, 05:14 PM   #1
Quint362's Avatar
Trailer: Hunter Compact ii
Kentucky
Regulator and hoses
I am going to have change the hose and regulator on my Hunter Compact ii. I picked up a new tank along with new regulator. Came with hose attached. The connector from the new hose is a 3/8 and the propane pipe on my camper is much larger. Can anyone tell me what type to buy and were to get it??
Quint362 is offline   Reply With Quote
Old 03-06-2012, 07:13 AM   #2
Quint362's Avatar
Kentucky
Name:	camper hose connector 031.jpg
Name:	camper hose connector 032.jpg
Old 03-06-2012, 07:14 AM   #3
Quint362's Avatar
Kentucky
The connector I have is to small does any one know if there is a adapter? Before I can get the camper license I have to have the Fire Marshall inspect it. I already know my tank is way to old. I'm am just bummed ..why can't things just go smooth?
Old 03-06-2012, 07:27 AM   #4
Thomas G.'s Avatar
Hi Deborah,
The adapter that you need is a brass fitting that can be found at a hardware store or Home Depot. Take the new part with you and a photo of the connecting pipe on the trailer. They will give you the proper adapter and teflon paste to seal it.
Old 03-06-2012, 07:31 AM   #5
Trailer: scamp 13
yup,,,what thomas said.
Old 03-06-2012, 07:39 AM   #6
On my Compact jr. the pipe under the trailer is 1/2" (NPT) National Pipe Thread. My trailer has a hose with 1/2 female NPT on one end and the other end fits the regulator. I was in Lowes Sat. looking at gas fittings and they should have what you need. The gas fittings were in the heating department at that lowes with the winter gas heaters not the plumbing section.
Take your hose to Lowes or your local gas supplier and they should have the fitting you need. Also use pipe dope or teflon tape for gas and check for leaks on all the fittings after you are done.
Eddie
Old 03-06-2012, 07:58 AM   #7
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
A "Farm & Fleet" or "TSC" store has a wide selection of propane brass fittings and hoses. The prices are usually good, too.
Spanke
Trilliums Rock!
Old 03-06-2012, 06:02 PM   #8
Quint362's Avatar
Kentucky
Thanks to all you swell folks!!
Name:	<a title=propane connector.JPG Views: 6 Size: 86.5 KB ID: 43721" style="margin: 2px" />
Old 03-06-2012, 06:07 PM   #9
Quint362's Avatar
Kentucky
Sprayed with soap and water and it don't leak.
Old 03-06-2012, 07:32 PM   #10
Thomas G.'s Avatar
Good job! Now you can pass it on.
Old 03-13-2012, 11:44 PM   #11
Roy in TO's Avatar
How in the world can a new tank be way to old?
Did you buy NOS?
(New Old Stock)
Propane Regulator Greg G. Care and Feeding of Molded Fiberglass Trailers 7 07-14-2010 07:46 AM
Question about propane regulator Bobbie Mayer Problem Solving | Owners Helping Owners 13 02-14-2010 03:29 PM
Propane regulator Dana T Problem Solving | Owners Helping Owners 1 09-20-2009 02:34 PM
Propane regulator Kevin K Problem Solving | Owners Helping Owners 9 04-24-2008 05:08 PM
Changing LP regulator Legacy Posts Problem Solving | Owners Helping Owners 10 07-02-2003 08:04 PM
