Removing water heater - Fiberglass RV
Old 01-27-2013, 11:37 AM   #1
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
Has anyone tried to remove an electric water heater from an older Scamp? I have a 1984 19' 5er and I want to remove the old electric water heater. Unfortunately it doesn't seem to want to come out through any of the openings. I hate to cut up the cabinet so I may have to take it out. I'm thinking Scamp must have built the cabinet after putting the water heater in place.
Old 01-27-2013, 02:05 PM   #2
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Mine has a year old one in it, I was trying to figure that out, too.
Old 01-27-2013, 02:39 PM   #3
I thought all cabinets were either riveted or screwed to the floor/walls. If you have fiberglass cabinets, it's not like they created the cabinets inside the trailer. I think you just need to find and remove the cabinet fasteners, pull the cabinet out and then you can get to the hotwater heater and that plumbing.
Old 01-27-2013, 02:55 PM   #4
honda03842's Avatar
Name: Norm and Ginny
I think all water heaters go in from the outside, either screwed or riveted to the fiberglass from the outside.
Simply remove the screws, discinnect the water, propane and electricity and it slides out.
Generally no need to remove cabinets
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 01-27-2013, 03:04 PM   #5
Not the one in my 1988, the outside opening is too small. Neither would it come out through the top hatch of the dinette cabinet. The bend/cabinet would have to be removed.
Old 01-27-2013, 03:43 PM   #6
Norm,
These are 6 gallon home style 110v hot water heaters not propane water heaters. A big old round "house" water heater.
Old 01-27-2013, 03:49 PM   #7
Steve, is there a quarter round or does the carpet butt right up againt the bottom of the cabinet? You'll probably need to pull it back to see where the cabinet is fastened to the floor. Along the wall, there are blocks the cabinets are fastened to. Can you see anything along the back wall, or get your head (mirror) inside the cabinet?
We know the cabinets come out, we've seen pictures where members have pulled them out to paint them...
Old 01-27-2013, 04:00 PM   #8
I'm taking the cabinets out anyhow, was just hoping there was an easier way. I now have most of my remodel stuff and will strip it as soon as I get back from Quartzite. The cabinets and benches are coming out and not going back in. I just don't want to ruin them in case I or someone else needs them in the future.
Old 01-27-2013, 05:45 PM   #9
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I thought this problem rang a bell...
Here's a link to a thread from last year where a member with a Scamp of unknown age was able to get the water heater out the side opening after drilling out the rivets (pic of opening below)
Francesca
Old 01-27-2013, 05:48 PM   #10
Steve's hot water heater is different Francesca. Imagine your home hot water heater (round), but squatty... a 6 gallon. It's the same one in my 1988. Mine continues to work just fine (with an anode change), but Steve's seems to have died... or he wants something different.
Old 01-27-2013, 05:51 PM   #11
Well, I wasn't sure, and thought maybe someone else with the same problem (but maybe different year trailer) might learn something from the other thread, too!
Francesca
Old 01-27-2013, 06:24 PM   #12
Someone searching will appreciate your effort Francesca!
Old 01-28-2013, 12:00 AM   #13
Not sure if it works or not. What I know is it won't work unless I'm plugged in somewhere. If I'm plugged in generally that means I have showers, restrooms, etc and really no need for a hot water heater. I was over where it is stored and going through some of the things that I want to do when I came upon this huge monstrosity under the sink. I was just wondering how the heck people get that thing out of there or change it if they have to.
Old 01-29-2013, 04:56 AM   #14
Steve, I suppose you could try to tear it apart while it's still in the cabinet. But, once you go down that road and if it doesn't work... you'll still need to remove the cabinet. I'd remove the cabinet before I butchered it up by cutting a bigger hole. YMMV
Water heater rgrugg Problem Solving | Owners Helping Owners 10 12-15-2012 02:13 PM
Water Heater???? Crackedegg Modifications, Alterations and Updates 22 10-06-2012 12:00 PM
Water Heater Q Eric & Tam Problem Solving | Owners Helping Owners 3 06-19-2007 07:00 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Duo-Therm heater - removing the cover WendyM Problem Solving | Owners Helping Owners 4 05-13-2006 09:51 AM
