Replacement Toilet -1977 Boler 17' - Page 2 - Fiberglass RV
Old 08-31-2016, 10:42 AM   #15
Name: Dave and Bonnie
LiseKen
Here is a photo of my above stove cabinet supports.
On left side is a stainless steel square rod, the other is now
supported by PVC pipe, not a piece of 1x1 wood. The square rod is original but I only have one. I believe that type of rod may be easily found in a sheet metal repair shop
Often I see supports of twisted steel like you would see on a staircase
I will be checking the water system shortly on our Boler - I think ours may
be in good shape except for the drain plug in the water tank. Do you have
an electric pump for your water to your sink or is it by hand pumping?
daveandbonscott is offline   Reply With Quote
Old 09-04-2016, 12:52 PM   #16
Your photos didn't show up, can u repost?
Mine has an electric pump mounted on the floor under the sink. It is a shurflo not sure the model. Want me to check?
Lise in WA
LiseKen is offline   Reply With Quote
Old 09-05-2016, 10:18 AM   #17
Shelf Supports
I have a Sure-flo as well. Like your, I will seek out a Boler owner near me to come and give some advice about appliance operation.
Have cleaned outside of trailer ( Barman's Friend wipe on with cloth and then immediately rinse off) and Bonnie painted 1/2 of trailer's interior ensolite with
Bullseye Primer to clean it up - worked weil with a small paint brush and a mini-sized roller.
Old 09-07-2016, 09:59 AM   #18
Sounds like you are making progress. I got a great handle on my leaks with the help of Karin of Campster fame, so they are in a holding pattern until I can get to them.
Am currently readying for my first outing (!), so have shifted to getting the inside sleepable. Mattress and curtains.
Your photos of the rod supports still didn't show up, am hoping to get something in before I go to keep the motion from causing any more roof sagging.
Here is a how to on adding photos to a post: Fiberglass RV - FAQ: Reading and Posting Messages
Lise
Lise in WA
Old 10-16-2016, 08:45 AM   #19
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
Lise,
Just noticed your remarks about your hitch coupler and roof supports. Here are my thoughts:
Hitch coupler: If the coupler latch doesn't latch, i.e., it only goes part of the way down, try turning the adjustment nut under and inside the coupler until the tightness is "just right".
Roof supports: Yes, I definitely agree that these should be re-installed on the countertop. My roof supports look like this, but I've seen other styles as well (photo only shows 1 support but there are 2, one on each side of counter):
boler
Sealand Toilet Flush Ball Replacement Gasket Doghaus Problem Solving | Owners Helping Owners 8 03-03-2017 07:45 AM
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 01:46 PM
17 foot Boler toilet replacement Kinslayer Modifications, Alterations and Updates 8 10-17-2013 04:00 PM
1977 Boler Door Handle Replacement Johnathan Gallant Problem Solving | Owners Helping Owners 29 06-08-2013 12:38 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 07:17 PM
» Virginia Campgrounds
