Scamp 16 Shower pump outlet - Fiberglass RV
Old 07-10-2016, 01:24 AM   #1
Greetings,
I have a Scamp 16 with forward bath. The shower pump works fine, but underneath the outlet just pumps out onto the ground. It appears a plug or part is broken off the side of it.
Does anyone have a picture of what it is suppose to look like... and can you tell me how the shower water gets into the grey water or black water tank?? I do not see a place for a line to enter.
I searched through the threads and didn't see this exactly... your help is appreciated as always. I wish the manual had better schematics of the systems.
Thanks much,
Teal
Teal is offline   Reply With Quote
Old 07-10-2016, 05:42 AM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
No picture here, but you should see the shower pan drain and the sink drain (if you have it) come together, then go to a screen (which protects the pump) with a clear screw-on cover, then the pump and then another length of soft drain pipe. This pipe might go through one of the rectangular tubes that is part of the frame, then enter the grey water tank.
Relocating Shower Pump on Scamp 16 Teal Modifications, Alterations and Updates 18 12-23-2015 06:31 AM
Shower Pump Dan Meyer Problem Solving | Owners Helping Owners 0 06-26-2014 08:40 PM
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
Post-2006 13' scamp shower drain pump relocation? JohnF Plumbing | Systems and Fixtures 6 11-16-2011 08:47 PM
