scamp kitchen sink - Fiberglass RV
Old 12-06-2019, 08:26 AM   #1
North Dakota
scamp kitchen sink
I have a 2008 19 foot deluxe Scamp, does any body know what the rough opening is for the sink? I do not want to start on the project until I have all the parts I need to finish. All that Scamp parts store offers is the acrylic sink, I would like to go with stainless steel. Also does anyone know of a source that would have a suitable replacement sink?
hghsl is offline   Reply With Quote
Old 12-06-2019, 09:43 AM   #2
Trailer: 2008 Casita 17 SD
Not sure what your galley counter configuration looks like since I don't have a Scamp, but in my Casita 17' SD, I couldn't stand that little "bird bath" of a useless sink that it came with, so I ripped it out and installed this one instead. Here's the write-up of my project that I posted on the Casita site. FWIW, hope it helps or at least gives you some ideas for something actually useable.
(From my Casita site post)
"Well, I just had enough of the small, relatively all-but-useless, galley sink that came with my trailer. Since I have the SD model, I didn't have enough room to install a standard 15" X 15" sink which are commonly available everywhere. I had to look long and hard to find one that was deeper, longer (front to back) and still not any wider than 14" which is the maximum space between the microwave cabinet bulkhead and the stove. I finally found one that was twice as deep, two inches longer, (front to back,) and basically the same width as the existing sink. It also comes with a 3" stainless steel drain and a swiveling 6" high goose-neck faucet assembly, which directly connects to the existing 1 1/2" drain line and the existing PEX hot and cold lines without having to do anything more than whack off about 5" of the vertical drain pipe in the cabinet under it. After removing the old sink, taping over the hot & cold PEX pipes to keep debris out, and "templating" out the rough opening cutouts that I would need to make for the new installation, I got out my Roto-Zip and had at it.
I won't say that this installation was easy for me, since I couldn't fit my large carcass into the cabinet under the sink. It was all reaching in as far as I could and most of securing the sink clips and hot and cold lines was a "mirror job" with the use of many improvised tools, but despite the fight I had with doing this one, it's in!
The (4th) picture, with the white paper plate in it, is showing how deep it is. That's a 10.5" diameter plate!
The new sink is made by Krowne, and is their Model HS-1419"
https://www.katom.com/381-HS1419.html
Kitchen or no kitchen? AJCmedia Modifications, Alterations and Updates 44 04-02-2016 03:25 PM
Slow draining Scamp 16 kitchen sink DougOlson Problem Solving | Owners Helping Owners 8 02-17-2016 03:54 PM
Larger kitchen sink for Bigfoot 17 foot Otto J Modifications, Alterations and Updates 0 07-08-2012 08:45 PM
Kitchen sink repair and re-seal brian m. Problem Solving | Owners Helping Owners 5 12-01-2007 02:43 PM
Winterizing the kitchen sink jrnutpaul Problem Solving | Owners Helping Owners 2 02-28-2007 08:01 AM
