Scamp Water System - Fiberglass RV
Old 10-28-2012, 03:49 PM   #1
RonnieV's Avatar
Trailer: 2004 Scamp Side Dinette 16 ft / 2006 Honda Pilot
Scamp Water System
Okay. I have had it. Going in circles trying to figure out the hot water connection (cold is the same) for the shower in my '04 Scamp. Water tubing is exposed on the closet side which is bad enough. Then the clothes rod fell and dragged the hot water tube out at the faucet connection. I've done some work as a plumber's helper and do all the plumbing on my house. But, I'll be darned if I can figure the concept here. Can't get the tube connector to seat and stay in place. Maybe an O ring or something disappeared with the flood. Anyway, I am going to get rid of the set up like I did the sink faucet. I replaced that with a small bar faucet with real brass fittings. What a concept. Any good ideas out there for changing out the shower faucet? Rather not have to change the tubing. How do I mate to that?
RonnieV is offline   Reply With Quote
Old 10-28-2012, 06:19 PM   #2
Trailer: 2014 Escape 21
Virginia
A picture would help. On my 2004 S-19 the trailer is plumbed with PEX. My trailer uses a PEX 90 degree 1/2 barb to 1/2 female pipe connection. You can get them from Lowes or Home Depot. They are fairly inexpensive compared to the other PEX fittings. You will need a PEX crimper and crimp ring if you need to replace the fitting.
I think Scamp may have used the connection method of expanding the pipe and let it contract around the fitting that method did not use crinp rings. I would replace both the fittings and use crimp ring fittings and crimp rings.
Eddie
Old 10-28-2012, 07:18 PM   #3
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
For just one connection splurge and get the PEX compression fitting. They are more money but by the time you get the crimper etc you'll be better off.
Water system question for 1991 Scamp LurkerDan Problem Solving | Owners Helping Owners 11 10-17-2014 01:12 AM
U-haul VT-16 Water system Matt in SV Plumbing | Systems and Fixtures 6 05-17-2010 08:17 AM
13' Scamp Water system diagram Wilder Plumbing | Systems and Fixtures 4 08-26-2009 07:52 PM
Losing prime in water system Paula D. Plumbing | Systems and Fixtures 19 06-07-2006 12:58 PM
Water system jefh Care and Feeding of Molded Fiberglass Trailers 6 01-17-2006 01:27 PM
