See Level Sensors for Bigfoot ? - Fiberglass RV
Old 08-10-2019, 05:56 PM   #1
currinh's Avatar
South Dakota
We have an Escape 19 on which I've installed SeeLevel tank sensors. Not too difficult as the tanks are not enclosed, ours has no foam under insulation. The wires can be run behind the corner moldings. I really like the SeeLevel system.
We're considering moving to a Bigfoot trailer, 21rb or 25rq. Can anyone tell me how the tanks are enclosed? How hard would it be to mount SeeLevel sensors to the Bigfoot tanks. Well, the mounting would be easy but I'm wondering about access to a clean side of the tanks for mounting. Also, any suggestions for bring wiring to the upper cabinets?
Thank you for your help.
Hugh Currin
2018 Bigfoot 25' Rear Queen
RAM 2500 diesel
Box Elder, SD
currinh is offline   Reply With Quote
Old 08-22-2019, 11:05 AM   #2
I replaced the factory sensors with See Level on a 21'. The freshwater tank is easy to access and hook into the existing wiring. For the other 2 tanks, you have to drop the fiberglass shroud. That took a few hours to remove the many screws and cut some mounting stuff around the tank valves. It wasn't hard to remove or put back together, just time consuming.
I did not like the original sensors, not very accurate or good resolution so, to me, very worth the effort.
Ben
btroxell is offline   Reply With Quote
Old 08-22-2019, 09:48 PM   #3
currinh's Avatar
South Dakota
Ben:
Thanks for the reply. Good to hear it is possible and not too difficult.
We looked at a 2020 25RQ Bigfoot yesterday. It looked like a galvanized sheetmetal piece at the front and rear of the tank enclosure. A lot of screws and some caulk, but it looked like this would come off without trouble. Wouldn't know for sure till it was done though.
What year is your 21?
Thanks again.
Hugh Currin
RAM 2500 diesel
Box Elder, SD
Old 08-23-2019, 09:00 AM   #4
I have a 2018 21' trailer.
Have you looked at bigfootowners.com? It is the semi-official forum for Bigfoot. You can get a subscription for a short time and a while back, someone posted about removing the cover on a 25'er.
Ben
Old 08-23-2019, 08:07 PM   #5
currinh's Avatar
South Dakota
Ben:
2018 is like new so I suspect the tank enclosure is the same. Thanks.
I've looked at bigfootowners.com but didn't find much information. I suspect you need to be an owner/member to get access to the forums. Are these under the "Forum" heading? I'll see about getting a temporary subscription.
Thanks.
Hugh Currin
RAM 2500 diesel
Box Elder, SD
Old 08-27-2019, 07:33 AM   #6
Sea Level Sensors
These are the only sensors that Grant @ Bigfoot is using now.
Russ Foster is offline   Reply With Quote
Old 09-12-2019, 09:55 PM   #7
currinh's Avatar
South Dakota
We decided to get a 25RQ Bigfoot. We were also lucky enough to find a 2018 25RQ for sale in Los Angeles. Went over for a look and came back with a new to us trailer.
Our 25RQ has a built up enclosure (basement) for the tanks. Galvanized sheet metal on front and back with flat sheets, I think plywood/fiberglass, on the bottom. Lots of screws. It would be a pain to take it off and I think you'd have to take it all apart to put sensors on all three tanks. Possible but not trivial.
Thanks for all your insight.
Hugh Currin
RAM 2500 diesel
Box Elder, SD
Old 09-12-2019, 10:26 PM   #8
currinh's Avatar
South Dakota
Russ:
So the newer Bigfoots have a SeeLevel system? The readout on our new to us 2018 25RQ doesn't look like a SeeLevel. The readouts are E - 1/3 - 2/3 - F via rows of lights. The SeeLevels I've used before have a readout in % in about 7-8% gradation. I don't see any manufacturer's name on the existing readout.
Some non-probe (like capacitive) sensors would be great, and I hope it's true. Hoping this I'll likely use what's there at least till we start having trouble.
Thanks for the input. Can anyone confirm or deny what Bigfoot uses?
Hugh Currin
RAM 2500 diesel
Box Elder, SD
Old 09-13-2019, 11:28 AM   #9
My 2018 21RB was defiantly NOT SeeLevel. I believe they are Sensatank II, a discrete (reads in thirds) capacitive sensor. Attached is a picture of 2 of the original sensors installed on a tank.
They were placed close to where they belonged, not exactly , so there was some error in the reading. Also, I had problem with them a few times with them not reading correctly. So being an engineer and liking precision, I replaced the original sensors with SeeLevel sensors and have been very happy.
Ben
Old 09-13-2019, 05:59 PM   #10
Ben
Ben
My '18 21RB is not SeeLevel either. But, I would love to get a better, more accurate reading of what my water levels are. Can you just replace the freshwater? Or do you have to replace all 3 at the same time? Which IS the freshwater tank? I looked for something like your picture but I don't see it. Is that inside the fiberglass cover?
Thanks in advance,
Jon
JonRaw is offline   Reply With Quote
Old 09-13-2019, 06:11 PM   #11
Yes, the picture is of the tank and sensor inside the fiberglass shroud. I pulled the shroud off so that I could add a grey tank sprayer and the new tank sensors.
Theoretically you could just replace one tank but you would have to keep each sensor's panel since the readout is completely different and use different electronics to read the sensors.
In the 21RB, the grey and black tanks are slung under and housed in the 'basement' and the fresh water tank is in the hidden 'bump' in the storage compartment under the bed.
Ben
Old Yesterday, 02:26 PM   #12
Bob in Maine's Avatar
Trailer: 2019 Bigfoot 25 foot rear twin
Maine
Sea Level Sensors for Bigfoot
I own a 2019 Bigfoot 25RT and it does not have Sea Level sensors.
2019 Bigfoot 25 foot rear twin towed by 2018 GMC Sierra 2500 HD with 6.0 L Vortech
Bob in Maine is offline   Reply With Quote
Old Yesterday, 06:40 PM   #13
currinh's Avatar
South Dakota
Ben:
Does the readout look like this:
This is the readout in our 25RQ. I don't see any manufacturer or markings of any kind. It doesn't look like any Sensatank readout I could find. Did yours look like this?
I've used SeeLevel sensors on two previous trailers. No complaints. If I didn't have to pull the basement apart I'd have a unit on order.
Thank you.
Ben
Hugh Currin
RAM 2500 diesel
Box Elder, SD
Old Yesterday, 06:44 PM   #14
currinh's Avatar
South Dakota
Ben:
I think in our 2018 25RQ all three tanks are mounted in the basement. I think they go side to side, the black furthest back, gray in the middle and fresh furthest forward. Not sure how much room there is to get at the middle tank to apply a SeeLevel sensor.
Can anyone confirm this layout on a 25RQ?
Ben
Hugh Currin
RAM 2500 diesel
Box Elder, SD
bigfoot
How do water level sensors work? What to do when they don't? 17' Bigfoot. 1990. Nik Electrical | Charging, Systems, Solar and Generators 11 08-16-2017 06:11 AM
Level Commander II 1985 bigfoot tank level indicator evenweight Electrical | Charging, Systems, Solar and Generators 0 04-14-2017 09:27 PM
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
Tank Level sensors in a Boler John Jesse Problem Solving | Owners Helping Owners 2 01-16-2010 08:11 PM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
