sewer tank wax gasket? - Fiberglass RV
Old 03-30-2018, 11:27 AM   #1
Trailer: scamp 16
Looking under the Scamp I noticed the waxy like gasket of the black sewer pipe going to the holding tank is crooked and coming out. This gasket or seal is made of a waxy like material. Is the something that has to be replaced or can we just pack it back up there by reforming into back? thanks
hiker22 is offline   Reply With Quote
Old 03-30-2018, 01:24 PM   #2
Trailer: Boler
BC
You should replace it, you can buy wax or foam ones they are cheap, puting them in is a lovely job, eau de toilet is the parfum of choice.
We're lost but we're making good time.
Eggcentric is offline   Reply With Quote
Old 03-30-2018, 02:24 PM   #3
floyd's Avatar
The outlet on the blackwater tank is a threaded fitting. A waxring is often used to seal the floor opening around the outlet to keep "critters" out.
It serves no plumbing purpose.
Mine just has silcone caulk applied from below.
You can simply scrape it off level from below and caulk around it or just leave it as it is.
Old 03-31-2018, 06:21 AM   #4
I believe that in the side bath model at least, when the shower is used, the wax ring under the black water tank functions to contain the water in the shower pan (floor) and prevents the water from coming out the hole in the case that water accumulates because the drain pump is off or clogged (or the camper is bow high). I suspect that is you have the same type of arrangement, and leave the drain pump off while running water in the shower, that you will see water come out the black water drain pipe hole if the wax ring has deteriorated.
As a secondary function, it blocks insects, snakes, etc. I am sure you have to remove the entire commode and tank to replace it, a PIA. Its a standard commode wax ring, although not used to seal in the same way (at the base of the commode).
You will have to decide if it needs to be replaced based on you needs. You could seal up the hole from underneath to block critters, but if water from the shower pan gets on top of the sealing, it will be in the floor (under the shower pan) and rot would no doubt follow. If you never use the shower, then thats not an issue (unless maybe the commode starts to leak into the shower pan).
At least thats how I understand the construction. Perhaps instead of just a cutout for the black water drain pipe, the shower pan should have a sealed "funnel" through the floor with the drain pipe run through it, so that water could escape the shower pan to the ground.
Old 04-02-2018, 03:37 PM   #5
On my Scamp with the side bath (since moved to the front) the floor was pretty much rotten from years of leaks.
Old 04-24-2018, 10:25 AM   #6
Trailer: Scamp 13 Layout B
This is a very helpful discussion. As it turns out my 13 ft Scamp has a leak under the blackwater tank so pulling it is one of my spring chores. Some questions I have are: 1. the Dometic manual says to cut the 3" black plastic discharge pipe. Do I reconnect with a no-hub coupling? 2. If the leak is from the threaded fitting on the bottom of the tank, how do I seal it? 3. The floor flange between the bowl and tank is deteriorated. Anyone know where I can find a new one? 4. Anything else I should know? Thanks so much!
sweendog is offline   Reply With Quote
Old 04-24-2018, 10:38 AM   #7
Originally Posted by sweendog View Post
This is a very helpful discussion. As it turns out my 13 ft Scamp has a leak under the blackwater tank so pulling it is one of my spring chores. Some questions I have ...
http://www.fiberglassrv.com/forums/f...own-66606.html
also
http://www.fiberglassrv.com/forums/f...eak-75066.html
http://www.fiberglassrv.com/forums/f...amp-43139.html
wax on....wax off CountrysideGrace Care and Feeding of Molded Fiberglass Trailers 20 01-03-2018 04:20 PM
What's the best wax? BOBSMITH Care and Feeding of Molded Fiberglass Trailers 6 05-26-2006 08:08 AM
Seapower clean&wax Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 07-06-2003 02:27 PM
My way to apply wax Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 06-15-2003 12:47 PM
Wax On... Wax Off... Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 04-19-2003 09:19 AM
