Shore water stutters - Fiberglass RV
Old 11-22-2009, 07:55 PM   #1
Trailer: 2004 Bigfoot 25 ft (25B25RQ)
I've been fulltiming for just over two weeks. I don't know whether it's gotten worse, or just bothers me more. When I turn on the water (hot or cold) it starts strong, then becomes a trickle, then gets stronger.
Does this indicate that I bought a cheap (poor quality) water pressure regulator?
I understand the water pressure here is very strong and a regulator is required.
Phil Ruffin
Phil Ruffin is offline   Reply With Quote
Old 11-22-2009, 09:40 PM   #2
Dan Meyer's Avatar
I'd bet it's no big deal. It might be caused by your water heater heating water, causing it to expand and raising water pressure. This will be seen by your pressure regulater and it will shut off the flow. Since the water pressure is very high, it will take a moment or two for the regulator to react. Have you tested your plumbing without a pressure regulator?
-- Dan Meyer
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 11:43 AM
Hot water coming out of the cold water side Matthew A Problem Solving | Owners Helping Owners 0 06-01-2010 09:37 AM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
