Show me your faucet - Fiberglass RV
Old 03-05-2013, 09:40 PM   #1
Chris Jones's Avatar
Trailer: U-Haul
Show me your faucet
If you would please could you post a pic of your faucet. I have a 1gpm pump to install in my U Haul CT and I'm looking for a better faucet than the original pump unit. A bathroom fixture will not reach because I want to mount it into one of the original holes. It does not need to have the pump or a switch in it.
Chris Jones is offline   Reply With Quote
Old 03-05-2013, 10:20 PM   #2
deryk's Avatar
New Jersey
Mine is on the list for replacement... Want something with a little more style!
deryk
Old 03-05-2013, 10:32 PM   #3
Mine is new, similar to Deryk's, but with a higher spout.
Old 03-05-2013, 10:34 PM   #4
deryk's Avatar
New Jersey
I figure its a cheap model... want something a little nicer... but its an eventual project lol... not a do now kind lol
deryk
Old 03-06-2013, 05:42 AM   #5
All stainless, hi-rise spout (for my coffee cup!) on four-inch centers. Love the paddle handles!
Old 03-06-2013, 07:12 AM   #6
Kevin K's Avatar
Trailer: 1983 13 ft Scamp
$31.90 shipped
CMS Polished Chrome Island Faucet 4" Center 4001 PC | eBay
Old 03-06-2013, 08:10 AM   #7
Thomas G.'s Avatar
Ikea has some nice ones that are reasonably priced. Also look on eBay if you find one you like, but find it too expensive. I've gotten great deals there on brand name faucets in the past.
Old 03-06-2013, 09:35 AM   #8
Trailer: U-Haul
I like the Lab faucets for only cold because I can bring them in the original hole and they have the paddle handles off the side of the goose neck. But ey are more expensive than the original ones.
Old 03-06-2013, 11:06 AM   #9
Thomas G.'s Avatar
Originally Posted by Chris Jones View Post
..But they are more expensive than the original ones.
Check eBay. There is a huge mark up on faucets.
Old 03-06-2013, 11:13 AM   #10
Dennis Clinton's Avatar
Trailer: Scamp 16'
Utah
I'm going to replace mine with a high neck single handle tap faucet-the kind they sell with reverse-osmosis filters in the big box stores. It's only a 1/4" faucet(for filling cups), but that's enough for me in the trailer.
Dennis
Dennis Clinton is offline   Reply With Quote
Old 03-06-2013, 07:19 PM   #11
Mouse's Avatar
Trailer: U Haul CT13
This is from Ikea.
It uses the original faucet hole. I raised it a little to make a little more space and to fit the opening. It swivels easily to move it into and out of the sink.
Mouse is offline   Reply With Quote
Old 03-06-2013, 07:23 PM   #12
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
How dare you ask to see my faucet? Next you'll be wanting to touch my faucet!!
Old 03-06-2013, 08:32 PM   #13
Trailer: U-Haul
Originally Posted by Mouse View Post
This is from Ikea.
So is this a hot and cold with both sides plumbed together? That's what I had in mind for mine with the plate to block off the other two holes from the original and give a little extra height to it.
Old 03-06-2013, 09:17 PM   #14
Mouse's Avatar
I connected both the hot and cold sides to the incoming water. That way water flows equally as I move the handle.
Old 03-10-2013, 07:41 PM   #15
Trailer: U-Haul
Here is what I wound up with. Thanks for all the ideas.
Old 03-10-2013, 07:58 PM   #16
D Davis's Avatar
Trailer: Casita, previously u-haul ct13
Virginia
Nice job Chris! Ha looks like you have the same chip on your back counter wall as I have on my CT What's up with that? But enjoy your new pumped water. Where did you install the pump, just curious....
D Davis is offline   Reply With Quote
Old 03-11-2013, 06:23 AM   #17
Trailer: U-Haul
The cat said this is where the tank will be and the pump will be mounted just in front of the tank. 6 inches of hose from the tank to the pump. I will post a pic when I get it in there.
Old 03-11-2013, 09:47 AM   #18
Unhappy Think about a noisy water pump!
I think that may make it noisy. My old pump sounded like a Semi's Jake Brake until I reconfigured the install when I replaced it.
Originally Posted by Shurflo installation guide
SHURflo recommends at least 1ft. of ½" I.D. flexible high-pressure tubing to both ports. The pump's ports/strainer should not be connected to plastic or rigid pipe. The pump's normal vibration may transmit through rigid plumbing causing noise, and possibly loosen or crack components.
Installation of a 50-mesh strainer (SHURflo P/N 255) is required to prevent debris from entering the pump.
Old 03-11-2013, 09:50 AM   #19
Thomas G.'s Avatar
Good point. If you need to mount it just 6" away, use an extra long piece of tubing and coil it. This isolates the pump vibration.
Old 03-11-2013, 12:51 PM   #20
Trailer: U-Haul
It's only a 1 gpm pump and the guy that sold it to me said it was very quiet. Plan on a little extra hose on both sides so it can be lifted above the water level for repairs or tank removal if need be. But that's a good point on the vibration in the lines. I hadn't thought of that.
Faucet Susanm34 Modifications, Alterations and Updates 3 03-27-2012 07:47 AM
Single Faucet Randy D. Plumbing | Systems and Fixtures 11 08-06-2011 04:15 PM
Have you seen this faucet? jlbails Plumbing | Systems and Fixtures 1 05-22-2011 01:48 PM
Faucet help for a '75 Trillium Kimberly E Problem Solving | Owners Helping Owners 5 08-13-2009 05:23 AM
Looking for Sink Faucet georgia g Problem Solving | Owners Helping Owners 6 06-21-2009 07:03 PM
