Shower Pump Question (Empty shower pan in 5th Wheel Scamp) - Fiberglass RV
Old 09-05-2013, 10:50 AM   #1
Trailer: 2004 19 ft Scamp 19 5th Wheel (Standard Layout)
Iowa
I was wondering if anyone else has had a problem with the pump that empties the shower pan. I am trying to figure out if I need to look at replacing it or not. Sometimes when I flip the pump on it doesn't start so I need to go outside the Scamp and tap the pump with a rubber mallet. Is that common or is the pump getting weak?
Thanks in advance for your help.
Gail
Gail Shook is offline   Reply With Quote
Old 09-05-2013, 11:52 AM   #2
kdhanso's Avatar
Hi Gail,
I recently replaced the shower pump on my 98 Scamp 16'. My pump motor still worked but the pump leaked. When I took it apart I found the rubber parts were shot.
I ordered the replacement pump from Scamp and also bought and installed the grey water filter. My former pump didn't have a filter and it probably contributed to the pump wear. The new pump is much larger and with 3/4" connections it drains the shower much faster. Due to it's size, I chose to mount the new pump under the recessed floor of the toilet area so it wouldn't hang too close to the road.
http://www.scamptrailers.com/parts-s...mp-detail.html
http://www.scamptrailers.com/parts-s...er-detail.html
Ken
kdhanso is offline   Reply With Quote
Old 09-05-2013, 11:59 AM   #3
kdhanso's Avatar
BTW, I called them to order rather than order on-line. I saved on shipping and was able to confirm I was ordering the pump they currently use for grey water. The web site wasn't too clear on that.
Ken
Ken
Scamp with shower question? Jerry71 Care and Feeding of Molded Fiberglass Trailers 14 03-24-2013 11:22 AM
Casita Shower Pan removal for floor replacement GMike A Plumbing | Systems and Fixtures 12 03-08-2013 09:45 AM
Post-2006 13' scamp shower drain pump relocation? JohnF Plumbing | Systems and Fixtures 6 11-16-2011 08:47 PM
shower pan-17' Burro Nadine Y. Classified Archives 5 04-09-2008 08:23 PM
shower drain scamp 5th wheel Legacy Posts Problem Solving | Owners Helping Owners 1 12-27-2002 06:45 PM
