SHURFlo water pump - Fiberglass RV
Old 06-11-2016, 11:36 AM   #1
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
SHURFlo water pump
My pump is making growling noises and the water pressure is weak. I checked and there's no bear or other wild animals in the pump that would growl.
Any suggestions as to the cause or cure?
It's not the size.....
reeves99 is offline   Reply With Quote
Old 06-11-2016, 12:30 PM   #2
Well, my first step would be to follow the troubleshooting guide in the manual... esp the section, "NOISY OR ROUGH OPERATION"
http://shurflo.com/images/files/RV_P...s/911-1024.pdf (Might not be the manual for your model)
Old 06-11-2016, 12:54 PM   #3
Raz
Raz's Avatar
Vermont
When mine stopped working I took it apart. I found a small piece of waste plastic that was stopping the diaphragm from operating properly. I removed it and put things back together. Pumps still working fine. I added a strainer to eliminate the problem happening again.
Old 06-12-2016, 10:18 AM   #4
reeves99's Avatar
Thanks for the suggestions. I took off the inlet and outlet pipes. No blockages. When the pump was re-priming it sounded fine. Then the noise started again. Hmmm.
So I checked the filter on the tap. And guess what? It was clogged. It's a goofy sort of multi-part filter, and until you take it apart you can't see the gunk in there. But I got it apart and cleaned out. And voilą. The pump runs fine now.
And what possible use is that stupid tap filter for anyway? Sheesh!
Adding shurflo water pump to sink. ?? AKSCAMP Modifications, Alterations and Updates 3 04-25-2016 01:56 PM
Plumbing in a Boler with Shurflo Pump VIDEO kevin61 Problem Solving | Owners Helping Owners 4 07-24-2008 10:38 AM
Shurflo Strainer for Water Line efawcett Problem Solving | Owners Helping Owners 8 08-02-2007 04:53 PM
SHURflo Comfort Air fan? Julia O. Modifications, Alterations and Updates 6 05-18-2007 07:40 AM
