Time to replace my water heater? - Fiberglass RV
Old 05-13-2018, 08:04 AM   #1
I'm in the middle of renovating our Scamp 19'. We have taken out all the dinette, water, electrical box and cabinetry. I'm looking at my water heater and the exterior access has a hole rusted clean through about an inch across. Is the "flange" that connects the heater to the trailer a replaceable part or is it time for a whole new unit? It looks like I can replace the whole unit from the outside of the trailer. Is there any reason why I should do it NOW while the cabinets are out? Can I patch it and replace it later? We have a 2000 19 deluxe. Gas only, no electirc ingnition or electric heating, I'm assuming it is the same as what they are still putting in it today. Atwood G6A-7. I'm not opposed to replacing it but if it is just a matter of replacing the flange that'd be great.
TXScamper is offline   Reply With Quote
Old 05-13-2018, 08:28 AM   #2
Paul O.'s Avatar
I just walked out to look at my 2004 water heater. I assume that your heater itself is OK. Is the one-inch hole below the drain plug, through the black formed sheet metal? That is where it may have been dripping and then rusting. In this case, I would just patch it. I would consider two or three layers of the aluminum duct tape. It sticks well and is tough.
Old 05-13-2018, 09:01 AM   #3
Photos might help.
Old 05-13-2018, 09:56 AM   #4
ibupnorth's Avatar
Trailer: 2018 Casita SD 17'
If you camp where you have access to electric and use the hot water for showers it would seem a good time to replace an 18 year old water heater with one that has an electric heat element too.
IBUPNORTH
ibupnorth is offline   Reply With Quote
Old 05-13-2018, 05:59 PM   #5
An old hot water heater is a problem waiting to happen. 18 years is way beyond expectations for one to last. I'd replace it while you are making your trailer nicer. After all if it leaks it could damage your improvements. Replace with an electric ignition and electric heat. You will be glad you did. We did that and it was simple to put in the switch which we did by the sink. But you can do it anywhere you want that is easy to access. When hooked to shore power use the electric heat part and when dry camping you can use the electronic ignition to light the heater. You'll never have to go out in the rain or bad weather to light the heater again. Just remember to always turn off the electric switch when unhooking shore power so if you hook up without water in it for any reason you won't burn it up. Our practice is to turn the switch off every time we unplug.
Old 05-14-2018, 05:54 AM   #6
Trailer: 2013 Escape 19
+10 get a new one that can run on either propane and 110.
Boler water setup??? new tank, pump & water heater question Johnny M Plumbing | Systems and Fixtures 7 05-07-2015 12:41 PM
Replace water heater valve? David Morgan Problem Solving | Owners Helping Owners 5 06-18-2012 03:51 PM
Next time you replace a rivet.... sfoss Care and Feeding of Molded Fiberglass Trailers 12 02-23-2012 08:14 AM
To Replace Or To Not Replace??? Susan Landis Modifications, Alterations and Updates 11 07-29-2011 09:19 AM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
» Trailer Showcase
Bo
arborbole
Babie
Naomi Payne
