toilet ball valve misallignment - Fiberglass RV
Old 06-12-2013, 10:50 PM   #1
Alaska
Our 2006 16' Scamp has a Dometic toilet. When stepping down on the flush lever the hole in the ball valve only meets the toilet bowl hole part way. Dometic troubleshooting says I need an adapter to lift the toilet allowing the lever to press down further so the entire hole in the ball valve matches the bowl outlet. Can I just adjust the lever? If an adapter is needed does Scamp really send these units out of their shop not working properly? Any chance Scamp would provide the adapter that was required in the first place?
Tom Smayda is offline   Reply With Quote
Old 06-13-2013, 05:39 AM   #2
Tom
You may already have this manual. Pop off the leaver cover and see why it won't depress the valve fully.
Eddie
http://www.marineworks.eu/en/help/do...28-Toilets.pdf
Old 06-13-2013, 01:37 PM   #3
Alaska
spring cartridge needed
I contacted Dometic. The tech said it sounds like I need a new spring cartridge $26. (I'm guessing this is part of the flush valve). The metal shaft rounds out the female end in the plastic pedal. A repair kit is more costly ($56) but includes a new flush ball, a better brass valve, and a spring cartridge. Selecting the link to the manual came up empty. Thanks for the help. tom
Replacing flush valve in SeaLand Toilet - Post #1 Fran L Plumbing | Systems and Fixtures 10 03-30-2021 10:38 AM
Sealand Toilet Flush Ball Replacement Gasket DogHaus Problem Solving | Owners Helping Owners 8 03-03-2017 07:45 AM
Installing cutoff valve in toilet water supply line Fran L Modifications, Alterations and Updates 15 04-08-2015 07:50 PM
Toilet Valve Steve Hammel Plumbing | Systems and Fixtures 4 02-03-2013 09:48 PM
dump valve - leak at knife valve DogHaus Problem Solving | Owners Helping Owners 3 09-29-2011 11:30 AM
