Toilet doesn't shut off completely - Fiberglass RV
Old 05-13-2011, 05:04 PM   #1
My toilet doesn't shut off completely, such that if I'm hooked up to a water source, over a 3-4 hours, my black tank will fill up completely. If I jiggle the flush handle it kind of helps a bit, but it will still eventually fill up. When I have a sewer hookup I leave the black valve open to prevent it from filling up. Otherwise if I'm using the pump, it's not a problem since I only switch the pump on when I want water. I don't see any way I can get into the toilet mechanism to see if anything seals can be replaced. Suggestions?
ThomasE is offline   Reply With Quote
Old 05-13-2011, 05:23 PM   #2
Trailer: Fiber Stream
I had toilet troubles in my Fiber Stream last year, and had to pull the entire unit to access the water valve. Mine was so old I wound up replacing the whole toilet.
I see you have a 17' Burro. When Gina D. had the same problem in her 17' Burro, she installed a shut-off valve in the line about 6" away from the toilet.
Old 05-13-2011, 09:04 PM   #3
Yep, in-line shut-off valve would be the easiest solution. Replacing the valve on the toilet may not be possible if the brand/model is no longer available. I'm not sure if that's the problem Gina ran into or not.
Old 05-13-2011, 09:17 PM   #4
Trailer: Scamp 16 - floor plan #4
Hi, Thomas,
What brand of toilet do you have? If it's a SeaLand, I may be able to offer some advice, otherwise, probably not so much.
Joe in MN is offline   Reply With Quote
Old 05-14-2011, 09:47 PM   #5
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I had an RV with a Thetford. the slide that opened when you flush got Toilet paper bunged and once cleaned out, worked fine.
Scott S. is offline   Reply With Quote
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
Windows that don't shut all the way tight?? Kathy Provost Problem Solving | Owners Helping Owners 4 06-02-2010 10:05 AM
Stove pilot light - no shut off Kevin H. Problem Solving | Owners Helping Owners 5 04-26-2009 09:38 PM
Keeping the ![at]#[at]$ door shut Coach George Jessup Modifications, Alterations and Updates 8 09-24-2008 04:59 PM
