Toilet leak - Fiberglass RV
Old 04-23-2012, 11:39 PM   #1
Trailer: 99 Scamp 16
Idaho
Toilet leak
I have a 16' scamp with a sealand toilet and it is leaking around base of toilet, it sits on top of the black tank. Is this an easy fix? Thanks for any help.
John
camper1887 is offline   Reply With Quote
Old 04-23-2012, 11:50 PM   #2
charliej's Avatar
Trailer: 2010 Casita 17 'Spirit Deluxe
There is a piece of plastic trim where the toilet meets the base. Carefully remove the trim. Under the trim are a number of bolts. Sequentially tighten them. Do not over tighten. You will probably find most were loose. That should solve the problem.
charliej is online now   Reply With Quote
Old 04-24-2012, 12:14 AM   #3
Idaho
How does the trim come off? Thanks!
Old 04-24-2012, 05:28 AM   #4
Is it possible you need a new seal? Sealand Toilet Parts
Old 04-24-2012, 07:10 AM   #5
IllAnnoy
I see your Scamp is a 1999. It was sold new with a plastic bag of hardware. If that bag is still with the trailer and it hasn't been used yet, there is a spare seal in the bag(part #14 in the diagram below). If it is not still there then Camping World sells Sea-Land or you can call Scamp for a complete seal kit.
Sealand Seal Kit
Image Detail for - http://www.laurelhurstdistributors.com/parts/toilets/sealand_trav-1.jpg
Old 04-24-2012, 11:01 AM   #6
charliej's Avatar
On the side with the flush pedal there is the seam. Pull forward on the front half while holding the back. I found tightening the bolts fixed my
minor leak.
Old 04-24-2012, 03:40 PM   #7
Dan Meyer's Avatar
minor leak.
It is super-easy, and much less disgusting thank you might think. In my Scamp I was having an odor problem and tightening the bolts easily fixed the issue.
-- Dan Meyer
Old 04-25-2012, 07:52 PM   #8
Idaho
Great thanks for the help! I will give that a try, if bolts don't fix it I'll throw in a new seal.
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
New Toilet tncruzin Plumbing | Systems and Fixtures 6 01-07-2012 07:06 AM
rv toilet Erwyn B Modifications, Alterations and Updates 1 09-02-2008 04:52 PM
13 ft with toilet Schirah Wanted: Molded Fiberglass Travel Trailers 6 11-05-2007 11:23 PM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
