Too much pressure - Page 2 - Fiberglass RV
Old 06-28-2018, 01:38 PM   #21
Trailer: '15 17' LD Casita and '17 Tahoe LT
I was told this years ago so don't know if it is still true or not. Was in Colorado Springs and was told by a dealer to be careful about pressure in the smaller communities because they get their supply from reservoirs at higher elevations and use gravity feed and the pressures can be pretty high.
dmad1 is offline   Reply With Quote
Old 06-28-2018, 01:46 PM   #22
tractors1's Avatar
Trailer: Escape 21 - Felicity
When I've had pressure regulators fail, they leak. I attach mine to the spigot as I would rather have the leak outside my trailer.
Definitely would not mount one inside the trailer for that reason.
Charlie Y
Old 06-28-2018, 01:52 PM   #23
Suggesting that those that run the community water supply have no clue as to what they are doing?
Old 06-28-2018, 02:14 PM   #24
The ones built in are no more likely to leak than a faucet, a pump, or a water line. As to the ones which go on the hose... Buy the brass,it only costs twice as much to go first class.
Old 06-28-2018, 02:29 PM   #25
I have a regulator on the end of the retractable hose reel I installed in my Scamp rebuild.
I would hate to blow out the swivel on the reel.
Sent from my SM-N910V using Fiberglass RV mobile app
Old 06-28-2018, 03:15 PM   #26
Steve Outlaw's Avatar
Trailer: Oliver
We were warned at a campground in San Antonio that their water pressure was in excess of 90 psi and to make sure to use a regulator. Putting the blue filter directly on the spigot was not the best idea. About ten minutes later the filter exploded and blew it’s entire contents in a five foot diameter debris field.
Steve and Tali - Dogs: Rocky and our beloved Reacher, Storm, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 06-28-2018, 03:44 PM   #27
sokhapkin's Avatar
SW Florida
I put regulator first because it is brass, but the filter thread is plastic. While travelling I connect/disconnect the hose daily (never stay at the same place 2 days in a row), this could damage filter's thread quickly.
Sergey
Old 06-28-2018, 06:32 PM   #28
was it one of these?...
Old 06-28-2018, 06:34 PM   #29
Trailer: Oliver
Yes it was.
Old 07-04-2018, 10:42 AM   #30
Trailer: Casita and Hemisphere
Kentucky
Maybe I’ve Missed Something
Originally Posted by Vanhamies View Post
We just checked in at the Lakehead Boat Basin RV and they warned me that the water pressure there was 110 pounds and offered to sell me a device to attach to the city water intake that would make the pressure acceptable for the Scamp. It costs $15 so I passed and just filled my tank. Has anyone ever heard of this sort of thing?
Why would you run filtered water through a hose that set in storage in the heat. My “egg” uses PEX tubing and fittings so I’m not worried about it...the problem is the hose in the sun with excess pressure. So I put the regulator on the faucet to lower pressure in hose, then hose, then filter at the trailer. The regulator has a screen washer on it for sediment.
oldharry2006 is offline   Reply With Quote
Old 07-04-2018, 12:45 PM   #31
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Sorry, but the first sentence there doesn't compute. why would filtering before the hose affect that in any way? And why would you not want to keep any sediment or other solids from damaging the regulator or hose?
I keep a spare filter on hand, but in ten years have never needed it due to overpressure, or any other reason for that matter. And of all those components, only the filter is designed to be replaced periodically.
But, we can certainly agree to disagree and go on enjoying camping together in our eggs.
Walt
Old 07-04-2018, 04:07 PM   #32
Kentucky
Originally Posted by Wayne Collins View Post
I put the regulator first, right at the spigot - then the hose - then the filter with a 90 degree fitting at the trailer inlet.
Exactly.....filter the water as close to where you use it. Why put filtered water through a hose that may contain contaminants.
Old 07-04-2018, 06:06 PM   #33
member
Isle of Wight
Because the hose doesn't contain any contaminants that the filter would remove.
And I dont want that filter hanging off my water inlet.
And I dont want ANY campground sand in my stuff.
WizWid is offline   Reply With Quote
Old 07-04-2018, 11:12 PM   #34
High Water Pressure Hookup
Early in my RV travels I visited the Boat Basin & RV Parking site. I was not warned of the high pressure and there we no signs addressing that issue. I hooked up my filter first. When I opened the valve the filter went off like a grenade--blown to bits! Subsequently I learned that the inside of your rig should never see water pressure above 40 lbs. (keeping it to 30 or less is best) or you're courting an interior flood and a lot of work, or big repair bill. So I bought a brass pressure regulator and I learned to protect ALL my gear by hooking up in this order: regulator-->filter-->hose-->RV. I've never had a problem since, and the regulator shows no signs of any deposits.
Jim
Scamper881 is offline   Reply With Quote
Old 07-05-2018, 02:32 AM   #35
Borrego Dave's Avatar
Welcome to FGRV Jim....you dodged a bullet there, good life's experience to pass on .
Old 07-10-2018, 06:02 PM   #36
Brian G.'s Avatar
Trailer: '73 & '74 Hunter
How do they work?
Suppose you don't use a pressure regulator. Instead, you turn the faucet on just a little bit, not even a half turn. What will happen? Will the pressure ultimately build up to the maximum? Or will the pressure remain a fraction of the maximum pressure? In other words, does the pressure regulator have the same effect as keeping the faucet turned down low?
Brian G. is offline   Reply With Quote
Old 07-10-2018, 06:07 PM   #37
tractors1's Avatar
Faucet turned down low regulates the flow, not the pressure - which will slowly build up to the output pressure of the spigot. A regulator has usually a spring-loaded diaphragm inside that will seal the output once the input pressure gets higher than designed (like 60 psi.)
Charlie Y
Old 07-10-2018, 07:59 PM   #38
So is it bad to drink from the hose? Been doing it for 50 years, am I going to die. If I die from drinking from the hose will I be hazardious waste? Put your pressure regulator at the hose bib and protect everything you own.
Old 07-10-2018, 08:17 PM   #39
Trailer: Sprinter 'til I buy
Denver, CO
Steve, I have bad news and good news. The bad news is yes, you are going to die. The good news is, not right now. Maybe in half a day, maybe in half a century, nobody knows.
I don't think drinking from a garden hose will shorten your life significantly. If it turns out that I am mistaken, try to have next of kin post to warn us.
Do be careful drinking from high mountain streams. Right after you take a sip, it seems you hike upstream and spot a reason you wish you hadn't.
Be well.
Tom 72 is offline   Reply With Quote
Old 07-10-2018, 08:21 PM   #40
Trailer: 2013Escape 21
Iowa
I like an adjustable regulator and have one with the filter on one end and a bib on the other end that a pressure gauge can show CG pressure or just a regular hose on it. I keep the pressure going to the camper at 40 PSI or below. I usually use two hoses the 25 goes to the area of my back bumper where I attach my filter and then a second short hose goes to the hookup on the trailer. In the picture , I happened to hook the filter to the regulator because the bib was high enough and water was close to the Eacape. Otherwise, I use a wrap of masking tape or black electrical tape to keep the filter on the bumper up out of the dirt etc. I’ve camped where pressure was 100 PSI with my regulator. Every water system is different and if a system is not looped where pressure is generally uniform throughout the system and instead the CG is on the end of the system, pressures can be high. Does a job on irrigation systems at times also. Laugh if you’d like, works for me. That’s a DCVA regulator assy to prevent backflow. Yes, I have stock in Continental Brass Company. YMMV
Iowa Dave
Iowa Dave is online now   Reply With Quote
You know you have too much stuff when.... Gina D. General Chat 26 10-03-2023 08:28 PM
How much squeaking is too much squeaking? NedMac Towing, Hitching, Axles and Running Gear 15 05-23-2016 07:01 PM
How much is too much?? Pamela H Problem Solving | Owners Helping Owners 10 07-04-2008 09:47 AM
Too Much Truck? Pete Dumbleton General Chat 6 02-06-2007 11:15 AM
How much is too much?? Legacy Posts General Chat 12 06-05-2003 08:31 PM
