06-27-2018, 06:24 PM
Too much pressure
We just checked in at the Lakehead Boat Basin RV and they warned me that the water pressure there was 110 pounds and offered to sell me a device to attach to the city water intake that would make the pressure acceptable for the Scamp. It costs $15 so I passed and just filled my tank. Has anyone ever heard of this sort of thing?
06-27-2018, 06:28 PM
SW Florida
Not unusual thing. I always connect to campground water supply using pressure regulator. The cost is $5-7 in walmart's RV supplies department.
Sergey
06-27-2018, 06:33 PM
Yes a pressure regulator should be standard equipment when using the the city water connection.. But when filling and using the on-board tank, as you did, it does not matter (unless your filler hose can not handle the pressure).
member
Isle of Wight
Yep - KOA in Alamogordo has a similar warning - but they dont try to sell you a regulator.
Here is how we ALWAYS hook up water.
Filter -> Regulator -> hose.
Have fun!
Jim
06-27-2018, 06:35 PM
SW Florida
Sergey
06-27-2018, 06:40 PM
I always use a pressure reducer when connecting to my supply line.
Most pressure reducers will be in the range of 45-60 pounds.
The fittings and pump may not be able to handle 100+ pounds.
06-27-2018, 07:00 PM
Have fun!
Jim
Interesting... I would have thought pressure reg first, to protect the filter. But I can see a good argument for the filter first (to protect the regulator from sediment)... Compare, contrast and discuss.....
BTW, the sale pitch was unusual but the price was probably fair, so perhaps they were looking out for you there.
BTW #2.. the most commonly used filter I think is:
https://www.amazon.com/Camco-TastePU.../dp/B0006IX87S
I use one and suggest it. Even then, I dont drink campaigner water very often.
06-27-2018, 07:09 PM
member
Isle of Wight
2 for the price of 1
https://www.walmart.com/ip/TastePURE...arbon/14504322
Then buy a flexible hose with shutoff from HD.
https://www.homedepot.com/p/Gilmour-...05HD/205886165
Flex -> filter -> regulator -> white hose
Jim
06-27-2018, 07:48 PM
Trailer: ,Retro by Riverside RV
I recently realized I had a pressure regulator on BOTH sides of my filter. I must be in pressure heaven!
Don't leave home without one. ( or 2)
Mark
Former Casita owner.
If you have a choice, Please buy, "Made in America"
06-27-2018, 08:11 PM
Our regulator is now built in to the shore water inlet, Always there, can't forget it!
06-28-2018, 09:56 AM
Trailer: 2017 Escape 17B
SW Virginia
That should come standard with all RVs really.
06-28-2018, 10:00 AM
SW Florida
Built in regulator doesn't protect the hose.
Sergey
06-28-2018, 10:06 AM
SW Virginia
Granted. But I'd be willing to chance a relatively inexpensive hose for the guaranteed protection on the plumbing. It'll be a rare event if ever.
Walt
06-28-2018, 10:11 AM
Mid Left Coast
i've had a lot of fresh water hoses that leak at the fittings at high pressure, but work fine after the regulator...
06-28-2018, 10:19 AM
SW Virginia
Okay, point taken. So maybe the ideal would be a built in, for secure trailer protection, and a $7 external one to protect the hose and fittings.
Walt
06-28-2018, 10:57 AM
That is a consideration, but damage is rare and a hose would be easily replaced. No problems so far and the trailer is protected.
06-28-2018, 11:04 AM
"Interesting... I would have thought pressure reg first, to protect the filter. But I can see a good argument for the filter first (to protect the regulator from sediment)…"
what you need is:
regulator ----->filter ---->hose ------>regulator-----> system ---->faucet ----->regulator. NOW you're protected!
<3
E>
Kai
06-28-2018, 11:25 AM
Have fun!
Jim
I put the regulator first, right at the spigot - then the hose - then the filter with a 90 degree fitting at the trailer inlet.
06-28-2018, 11:49 AM
member
Isle of Wight
Well I dont.
The only weight I want hanging off my city inlet is the hose.
The disposable filter goes first to keep the sand out of my stuff!
Jim
06-28-2018, 12:06 PM
SW Virginia
Yup. And really, only the filter is meant to be disposable, because its role is to protect everything downstream.
Walt
