trillium toilet help - Fiberglass RV
Old 01-04-2014, 10:38 PM   #1
bobby62g's Avatar
Trailer: 1979 trillium 4500
the toilet in my 79 Trillium 4500 has issues. the siphon pump to draw water to the bowl from my fresh water tank leaks & does not draw, the valve to let the waste from the bowl to the small holding tank leaks & finally the valve to contain the holding tank waste leaks. Rebuild / Replace
I can't even find out who made this.
Thanks Bobby
bobby62g is offline   Reply With Quote
Old 01-04-2014, 11:31 PM   #2
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Don't recognize the potty, but that may be because my head won't rotate on my neck enough to actually see the picture.
Kidding aside:
You're talking about a bunch of blown seals, and I've been there with my O.E. 4500 potty. Fahgeddabout replacing the seals...cost you as much as a new unit, especially once you consider the nasty factor involved with replacing some of those puppies.
A hundred bucks or so will get you a new Thetford 135, which is the closest thing to what you have, size-wise. It will fit in the cubby, and that's what counts.
Old 01-04-2014, 11:43 PM   #3
bobby62g's Avatar
wow quick reply, I would gladly buy another toilet that has a outside standard discharge valve so I wont have to carry the 2 gallon porti potty tank & empty it. One of the reasons I chose my trailer was the bathroom option.
Old 01-05-2014, 07:19 AM   #4
tractors1's Avatar
Trailer: Escape 21 - Felicity
I don't know the Trillium setup; maybe a regular marine head would work for you? This is a manual pumpout/discharge:
Thetford Aquamate 365 MSD Marine Head
Charlie Y
Charlie Y
tractors1 is online now   Reply With Quote
Old 01-05-2014, 11:41 AM   #5
I'm interested in the bathroom option your Trillium has, Bobby- I see what looks like vent pipe in the pic- what's that for? Also, does it have a shower, and if so, does the toilet have to come out of the "room" while showering?
I ask because that marine toilet looks like a good option if you have the room for a permanent install and want the "standard discharge" you mentioned earlier.
Old 01-05-2014, 11:55 AM   #6
bobby62g's Avatar
the pipe is abs painted white & vents the holding tank part of the toilet. the toilet, unlike a portable, has a permanent discharge directly under the tank which has a 3" connecter for hooking to a campground system or to a roll around tank one could empty if no direct hookup is available. the holding tank under the toilet holds about 10 gallons. Bobby
Old 01-05-2014, 11:58 AM   #7
bobby62g's Avatar
No shower yet, but my plumbing contractor buddies want to invent one.
Old 01-05-2014, 01:07 PM   #8
O-o-o-o-o-h...
I think I'm starting to get the picture. Threw me off when you mentioned "emptying the two-gallon tank" on the porta potty. I thought you were talking about the toilet in the pic, but that's wrong, right?
Am I correct in now assuming that the one in the pic is a permanent install and you're just using the PP 'cause this one leaks?
I see a label in the picture- anything useful there, identification-wise? Even just a part number or something?
Old 01-05-2014, 01:17 PM   #9
bobby62g's Avatar
the toilet in my 4500 is not a portable. at this point I am dissembling the thing to buy rebuild parts. so far i have identified the discharge valve as a thetford valve available online
I have found threads about the 727 toilet, but no results
Old 01-12-2014, 09:12 PM   #10
bobby62g's Avatar
so at this point, not being able to rebuild the stock toilet, I removed it & ordered a new thetford portable
trillium
Storing Toilet Paper Roll in Toilet-Shower Combo S Sato Plumbing | Systems and Fixtures 24 04-18-2015 12:46 PM
help!! toilet troubles... kelley m Plumbing | Systems and Fixtures 5 06-20-2013 06:40 AM
I need help installing toilet. Ed D Plumbing | Systems and Fixtures 39 05-08-2011 10:46 AM
Replace old toilet or go portable toilet Paddy Morris Plumbing | Systems and Fixtures 7 04-25-2006 06:17 PM
Trillium Portable Toilet Repair Legacy Posts Plumbing | Systems and Fixtures 7 01-31-2003 05:46 PM
