Waste Water Valve Problem - Fiberglass RV
Old 06-09-2013, 02:10 PM   #1
Trailer: 1980 16 ft Scamp (Restored)
The black water valve on my 1980 Scamp was leaking around the valve (bolts). I decided to replace the valve, and put an extension on the line so I could better operate the valve handle. The four bolts holding the valve on were totally rusted shut. I ground down the bolt heads which go in from the bottom of the valve. This enabled me to remove the valve and seals. HOWEVER, the bolts are still connected to the rusted nuts at the top of the square piece that is connected to the toilet. I can't remove them from the top, because they are just below the floor board. I tried hacksawing them off, but the space is too limited. Any suggestions of how I can remove those bolts?
Appreciate any responses.
Lawrence Walters
Frustrated in Albany, Oregon
Lawrence W is offline   Reply With Quote
Old 06-09-2013, 02:13 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Can you drill the heads off using a drill bit a little larger than the bolt shank diameter?
Old 06-09-2013, 02:36 PM   #3
The heads are already ground off. The upper ends are holding the bolts by the nuts, which are rusted shut. I suppose I could drill up through the bolt holes, but the difficulty is not grinding away the PVC that surrounds the bolts.
I have a photo, but nothing happens when I click on "manage attachments."
Old 06-09-2013, 02:58 PM   #4
Thomas G.'s Avatar
I'm having trouble visualizing this.
When you click manage attachments you should get a box that lets you choose a file from your hard drive.
Old 06-09-2013, 03:11 PM   #5
Nothing happens when I select Manage Attachmens or the "paper clip" icon.
Old 06-09-2013, 03:13 PM   #6
Thomas G.'s Avatar
Nothing happens when I select Manage Attachments or the "paper clip" icon.
Maybe try a different browser - Firefox, Chrome, Internet Explorer??
Old 06-09-2013, 03:31 PM   #7
I uploaded the photo using my wife's PC.
Lawrence
Old 06-09-2013, 04:52 PM   #8
Thomas G.'s Avatar
Lawrence
OK, so you need to cut off the nut that is on the top side of the flange in the photo?
Maybe one of these with a cut off wheel: 120 Volt 3" High Speed Cut-Off Tool
Heavy Duty 4-1/2" Angle Grinder
Or use this with a brand name (not HF) metal cutting blade: Multifunction Oscillating Power Tool - 1.6 Amp, 120 Volt
Another less desirable option would be to notch the corners of the plastic flange so the bolts come out. The mating piece will position the new bolts.
Old 06-09-2013, 05:04 PM   #9
Trailer: 2014 Escape 21, Lil Joe
Lawerence
Is the discharge pipe threaded into the bottom of the tank? If it is with the valve body removed you might be able to unscrew the pipe from the tank and replumb. (I'm not sure how the discharge pipe is attached to the tank.)
Eddie
Looks like it is threaded in. Check out this link.
Dometic Sealand 711 Traveler Toilet
Old 06-09-2013, 07:04 PM   #10
It was THREADED! See photo.
Thanks for your help!
Old 06-09-2013, 07:07 PM   #11
glad you got it off!
Old 06-10-2013, 07:07 AM   #12
Thomas G.'s Avatar
Great! As a guy, I'd never have thought of reading the manual.
Which waste water tote and Why? rabbit Care and Feeding of Molded Fiberglass Trailers 14 07-02-2012 06:26 PM
portable waste water storage swenny Problem Solving | Owners Helping Owners 1 05-25-2012 09:29 AM
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 6 05-20-2011 08:19 AM
Replacing waste gate valve handle Matt in SV Problem Solving | Owners Helping Owners 3 12-29-2010 04:38 PM
