Water filler - Fiberglass RV
Old 01-12-2014, 01:06 PM   #1
Wallo's Avatar
Utah
Water filler
The water filler on curb side back the 13' Scamp is ridiculous. A hose can not be propped up, and the water can only input at a trickle. Has anyone changed out this system or found a way to override it? Details and pictures would be a plus.
Thanx,
Alice
Alice
Wallo is offline   Reply With Quote
Old 01-12-2014, 09:12 PM   #2
The previous owner of my Fiber Stream installed a regular hose bibb (garden hose faucet) in the fresh water tank's drain.
I went to a hardware store and bought a female-to-female garden hose adapter (not shown) for less than $5 and keep it screwed onto the end of the bibb. Then I bought a screw-in cap like for the "City Water" port (not shown) and cap the fitting in the same way. When I want to fill the tank, I attach the white hose to the tank's drain bibb the same way I connect it to the "City Water" fitting. I open the valve as if I were draining the tank, then I turn on the water to the white hose which fills the tank through the drain quicker than using the tank fill port, which I open for venting. When the tank is full I close both the drain bibb and shut off the water to the white hose.
Old 01-12-2014, 09:34 PM   #3
FTTRV's Avatar
Trailer: tp
Water Filler
Here is a Water Filler that may work. You can visit my website to view other water fillers.
Chuck
Old 01-12-2014, 09:35 PM   #4
The Camco water filler hose works fairly well. You can insert the clear hose into the filler opening. Also sold at Wally World. I like the valve an the end of the hose.
Amazon.com: Camco 40003 RV Water Tank Filler with Shutoff Valve: Automotive
Eddie
Old 01-12-2014, 09:43 PM   #5
Thanx,
Alice
Pictured below is the solution found for a replacement of the Scamp water filler.
It has a tapered opening which allows inserting a filler tube or a garden hose or it especially works well with the tapered spout which is supplied with those green plastic jerry-cans found at the big-box store.
Old 01-12-2014, 09:57 PM   #6
tractors1's Avatar
Trailer: Escape 21 - Felicity
Thanx,
Alice
Similar to Fredericks drain redo, but I used a "laundry faucet" like on a washing machine, as it doesn't stick out quite as far and is equipped with a hose fitting male thread; no adapter needed.
Charlie Y
Charlie Y
Old 01-12-2014, 11:51 PM   #7
Trailer: Escape 5.0 TA
W. Mass
Just a heads up. I have a filler like Floyd shows, I found I could wedge a male hose coupling in the filler thereby keeping the hose straight while filling. Problem was when the tank filled, the pressure (which was pretty much wide open) needed somewhere to go and it found the weakest link at the hose clamp on the inside of the filler. I caught it pretty quick but not quick enough to avoid who knows how much pouring onto and eventually under the trailer floor.
Lesson learned, either don't overfill the tank or only fill at a rate where you have room for the overflow to come out, safely. I use a smaller diameter hose that leaves plenty of room at the filler spout.
What a mess.
padlin00 is offline   Reply With Quote
Old 01-13-2014, 12:01 AM   #8
Alice,
The stock Scamp fill inlet on my 03 has a little basin that protrudes out from the side of the trailer about 2", and has a hinged toilet seat type cover with a swing latch. It does not hold the hose well unless I aim the hose straight down vertically where the threads of the hose end sort of catch on the plastic ridges inside the basin. The water flow does have to be slow to keep it from backing up though. I guess patience is required, like using California approved gasoline fillers.
Russ
Old 01-13-2014, 06:14 AM   #9
Or, don't change anything and buy a cheap transfer pump. Leave the water container on the ground and pump to fill the tank. It will take some effort, but it's not like you're filling a 55 gallon tank: Multi-Use Transfer Pump
Old 01-13-2014, 08:50 AM   #10
Wallo's Avatar
Utah
Frederick, Chuck, Eddie, Floyd, Charlie, Bob, Russ, and Donna:
Thank you all for your input. It has given me some solutions to work with. Since I'm heading down to Las Vegas today for some shopping, I'll stop off at Harbor Freight and get the transfer pump and try it at Quartzsite. It's the easiest and least expensive solution to try at the moment. If it doesn't work, then I can look into other ways instead. Thanks to all for giving me good ideas.
Alice
Alice
Old 01-13-2014, 09:08 PM   #11
This thing fits on the end of a garden hose and has its own shut off,
Works great!....
Old 01-13-2014, 09:58 PM   #12
Yeppers Alice! Start cheap, if it doesn't work for YOU move to the more expensive. I'm cheap, can't help it. I often think, how OFTEN do I need to use (whatever). If it's an everyday item, that is totally different than something that makes my life easier (and cheaper) than something used a couple of times a year. YMMV.
Best of luck, truly
Old 01-13-2014, 10:25 PM   #13
papa-t's Avatar
Glade Valley, North Carolina
I found that if you take a hose like is used on a washing machine. Cut a 14 inch piece from the female end it will fit in the filler. Use that on the end of a regular garden hose.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 01-13-2014, 11:41 PM   #14
David B.'s Avatar
Works great!....
I have modified this by taking a very pliable soft hose and extended it down into the tank. I leave it there, and connect a metal hose end similar to above, to that hose and just fill it as fast as the garden hose can give gpm, as the displaced air just come out around the soft hose.
Dave & Paula
Old 01-15-2014, 09:29 AM   #15
I take a filler tube like floyd has pictured and screw it onto my hose.Then I drape the hose from the left side over the top of my spare tire then over to the filler port. The spare tire holds the weight of the hose up and make filling easy and free flowing.
Old 01-15-2014, 01:07 PM   #16
Wallo's Avatar
Utah
Donna: I'm with you, finding a less expensive way of doing something leaves me with more resources to do other things I enjoy. That's why I have a Scamp and don't stay at the Hilton.
Went to Harbor Freight and got the Multi-Use Transfer Pump Donna D. recommended. At some camping areas, state or national parks, the hoses used to fill a tank are just a rubber hose cut off at the end. There is no connector. Plus, I usually take a couple of 6 gallon containers and use those to replenish. They are very heavy to lift and steady. Alot of water ends up on the ground. I've had people comment that EMPTYING tanks is prohibited, not realizing the puddle is by my refill. We'll try this at Quartzsite and see if it works. If not, only out $8.
Thanks everyone for your suggestions, they were very helpful.
Alice
Old 02-15-2014, 02:14 PM   #17
Wallo's Avatar
Utah
Just and update. I used the Multi-Use Transfer Pump and found it was worth while. Went into Quartzsite, filled a 6 gallon container, got the siphon going and sat back talking to my next door neighbor while the pump did its work. Just keep the container above the inlet for water and everything is easy.
Alice
Old 02-15-2014, 03:44 PM   #18
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
For those who are squeamish about such things, that Harbor Freight transfer pump isn't made of "food grade" materials and really isn't supposed to be used for drinking water.
There are drinking water grade siphon pumps out there, though of course they're more expensive. here's a link to one .
Old 02-15-2014, 04:19 PM   #19
Ok I will bite. How did you keep the water container above the inlet while sitting back talking to the neighbours?
Old 02-15-2014, 04:40 PM   #20
Wallo's Avatar
Utah
The table I use for my camp stove sits higher than the inlet for the water. I just sat the container on it. If it was not available, I could have backed the Rav up and set it in the back.
Francesca: You are most likely correct about the food grade material. In my case, I never use the water for drinking. Just bathing and washing dishes. I carry drinking /cooking water in a 2 gallon container that I fill up at home.
This is why I rarely go camping where I have to boondock. Too much stuff to carry in and out with you.
Alice
Water Tank Filler davelikebike Modifications, Alterations and Updates 5 09-06-2013 07:53 AM
Water filler cover broken Janb313 Problem Solving | Owners Helping Owners 30 03-09-2013 06:25 PM
Water filler and cord access Gary Z Care and Feeding of Molded Fiberglass Trailers 3 03-30-2009 12:50 PM
Bed, tire cover & filler shirley munson Classified Archives 18 06-01-2006 01:57 PM
