Water heater bypass - Page 2 - Fiberglass RV
Old 07-15-2016, 07:50 AM   #21
I concur... that while my "Bypass" valve doesnt look exactly like that one, when you want water to flow into the water heater, the handle turns 90 deg and is then parallel to the "cold" water inlet pipe.
Originally Posted by Joe MacDonald View Post
Generally the handle points in the direction of water flow
Old 07-15-2016, 10:59 AM   #22
My 2004 Scamp came with a shutoff on the inlet to the hot water tank.
This is all that is needed to isolate the tank for winterization.
Yours doesn't have a shutoff?
Old 07-15-2016, 11:12 AM   #23
Floyd is there a check valve on the hot water side of the tank ?
Old 07-15-2016, 01:51 PM   #24
There is no check valve, but there are faucet valves which Isolate the hot water lines.
When winterizing, you flush the cold water until you have "pink in the sink".
With the hot water tank drained, you simply open the hot water faucet at the sink , hold your hand over the spigot and open the cold water faucet.
This will flush the hot water lines back into the tank, clearing the lines with anti-freeze. repeat at each sink/shower.
Old 07-15-2016, 08:01 PM   #25
Thank you for the information
Camco 35953 water heater bypass kit ThomasE Modifications, Alterations and Updates 11 08-27-2015 07:16 AM
hot water heater cyndi H Problem Solving | Owners Helping Owners 11 08-13-2013 12:50 PM
Where do I find the water bypass switch? Karalyn Plumbing | Systems and Fixtures 9 10-19-2006 01:30 PM
Hot Water Heater - Rusty Water terryw Problem Solving | Owners Helping Owners 9 07-15-2006 08:33 PM
Hot water Heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-30-2003 02:14 PM
