Water heater not working on propane. - Fiberglass RV
Old 04-21-2016, 12:02 AM   #1
Trailer: Parkliner
We have a Parkliner (and they are back in business) with a problem I could use some hints with. The water heater works well on a.c. But the propane quit heating the water last fall. The range works well so the gas supply is there.
Any help would be appreciated.
KayMarino is offline   Reply With Quote
Old 04-21-2016, 01:18 AM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Bill, have you checked and cleaned the burner tip for dirt, spiders and such? Doesn't take much to keep it from working.
Old 04-21-2016, 08:02 AM   #3
You dont say how old the trailer is. But you should either have a manual on the WH or be able to download one from the internet. I would do that and study up on the "Trouble-shooting" area.
I have an Atwood that's located at the rear of my Scamp. I've had to hold down the blue pilot light button until I thought something was wrong as well. It's just a SMALL amount of gas coming through the line to initially light the water heater so dont be fooled by how long it takes.
But you said it was working before so I'm sure you're familiar with how to light it etc. If you fail to find the answer with the manual, you can call the factory. My guess is the small tube is stopped up or your ignitor has possibly failed. Do you smell gas back there at all when it's trying to light? If not, I'd say it's definitely stopped up. Do I hear "little pests"?
Old 04-21-2016, 08:55 AM   #4
Trailer: Bigfoot B-17 CB
If you have electronic ignition, and with your fairly new Parkliner, you probably do. you could have a blown fuse. Open the outside door to the water heater and there should be a fuse or link that is bad, or maybe when the heater was winterized, the wire got disconnected.
Jack L is online now   Reply With Quote
propane
Refrigerator not working well on propane El Brazo Enophre Problem Solving | Owners Helping Owners 5 07-02-2015 09:33 AM
Fridge working on DC and Propane, but not 110 GregandTeresa Problem Solving | Owners Helping Owners 14 07-01-2015 04:16 PM
78 Trillium 4500 heater not working gomerthetrillium Problem Solving | Owners Helping Owners 28 01-28-2015 09:57 AM
Dometic Fridge propane meter not working GMike A Problem Solving | Owners Helping Owners 7 09-21-2014 04:58 PM
Water Pump Not Working After Air Compressing nathanj04011 Plumbing | Systems and Fixtures 4 10-29-2007 01:22 PM
» Trailer Showcase
TBD
LiseKen
The Pebble
BCPaul
