Water pressure regulator - Fiberglass RV
Old 07-01-2013, 10:33 PM   #1
Hello All,
Will be picking up my new Scamp 13' next month. The Scamp will have a sink, but not a toilet or shower. I was wondering if I will need a Water Pressure Regulator when hooking up to water at the campgrounds. I saw one at Cabellas a few days ago and hadn't even given it a thought until then. I would appreciate any ideas anyone has about this.
Thank you
Dave Harris is offline   Reply With Quote
Old 07-01-2013, 10:42 PM   #2
The water pressure regulator protects the plumbing in your trailer from being trashed by too high pressure. If you have a sink, I presume you have plumbing ( not always the case on this forum ).
It's cheap insurance.
Old 07-01-2013, 10:44 PM   #3
Always a good idea to use one. Pressure at campgrounds can vary greatly. Mine stays on my hose permanently.
Old 07-01-2013, 10:44 PM   #4
FTTRV's Avatar
Trailer: tp
water pressure reg
Originally Posted by Dave Harris View Post
Hello All,
Thank you
Yes buy one and use it. It will save your pipes from blowing apart.
Chuck
Old 07-01-2013, 10:50 PM   #5
Thank you Chuck, Carol and Glenn,
They are cheap enough, Will pick up one and add it to my collection of supplies going to Backus.
Old 07-02-2013, 04:37 AM   #6
Don't buy the cheap plastic regulator. The brass kind is only a couple of bucks more. When the brass regulator I own quit working, it turned out it was the rubber hose washer... the screen was plugged. Cleaned it well and it's good to go.
Old 07-02-2013, 06:15 AM   #7
papa-t's Avatar
Glade Valley, North Carolina
You can also buy a brass one at Walmart in the camping/RV section.. However, some newer campgrounds may already have regulators on the water hookups. Better safe then sorry. Congrats David on the new Scamp and welcome to the forum.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 07-02-2013, 08:37 AM   #8
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
"Need" is a pretty strong word. With all the pex piping I expect it isn't needed. However, I agree with the others that it is cheap insurance. I've always used one the few times I've had that option.
Old 08-26-2013, 09:26 PM   #9
felix2's Avatar
Trailer: 82 burro 13 "PookaBurro"
Does anyone know if any regulators are also backflow preventers (one way flow)? Or do I need a separate backflow preventer inline?
felix2 is offline   Reply With Quote
Old 08-26-2013, 09:42 PM   #10
The city water inlet on the trailer should have a one way flow regulator (backflow) built into it.
Old 08-26-2013, 10:03 PM   #11
Mine doesn't have a regulator or backflow. Just a short piece of pex going to the faucet.
The only times I've used city water there was a regulator already on the water tap.
Old 08-26-2013, 10:14 PM   #12
After I typed that Byron I realized that some of the older or cheaper city water connections may not have had a built in check valve. But even this pretty cheap one on e-bay claims to have a check valve.
Old 08-26-2013, 10:36 PM   #13
OLDER???
Older than what? Your Scamp is 14 years older than mine.
There's a difference in water systems. My city water connection goes directly to a faucet at the sink. The fresh water tank is not ever pressurized and I don't have a water heater, water pump, or shower. Pretty simple system. I do have a regulator/check valve. But I noticed that most of the campgrounds that have water hookups have a regulator/check valve attached to the their of the hookup. (water bib). If that's pretty much the standard a regulator/check valve might not be necessary. However it's pretty cheap insurance.
As for me I think I actually connected the city water 3 times in 8 years. I thinking I'm going to take the faucet out cause it seems always be the way. I can turn that into a paper towel holder.
Old 08-26-2013, 10:39 PM   #14
No Shower, no need for city water.
David,
Without a toilet and shower there's no need to connect to city water. Simply fill the fresh water tank. I have a trailer very much like yours. I don't use the city water connection.
You'll need to sanitize the fresh water tank as soon as you get it.
Enjoy.
Low Pressure Regulator jmacchi Problem Solving | Owners Helping Owners 5 01-23-2009 09:55 PM
Pinhole in Gas Pressure Regulator? Daisy Problem Solving | Owners Helping Owners 3 10-16-2006 09:01 AM
water pressure regulator Chris Z Problem Solving | Owners Helping Owners 9 07-05-2006 02:55 PM
Water Pressure Regulator jefh Care and Feeding of Molded Fiberglass Trailers 10 01-31-2006 07:26 PM
Water Pressure Accumulator Steve L. Modifications, Alterations and Updates 2 11-24-2005 03:32 PM
