WATER PUMP PROBLEM-Need Help! - Page 2 - Fiberglass RV
Old 05-26-2015, 03:24 PM   #21
HomeCamp's Avatar
Trailer: SOLD - Lil Snoozy 2014
East Tennessee
Originally Posted by charlsara View Post
You should be able to install the accumulator just after the pump. The fittings should already be there.You may need to remove the couch and water tank cover to get to it. The system will work OK without it but it sure makes a difference in the noise and lights flickering.
If the pump does not completely stop after the water is shutoff, you may have another problem.
Charlie,
Did you install an accumulator? All of my connectors are clamped with that special hand cripping tool.
Dan
HomeCamp is offline   Reply With Quote
Old 05-26-2015, 03:58 PM   #22
sokhapkin's Avatar
SW Florida
How often do you camp off grid and water connection? You don't need the pressure tank if that happens less than 25-30% of your nights.
Sergey
Old 05-26-2015, 04:05 PM   #23
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Dan,
The pump has screw on connectors. You won't have to remove the Pex connections unless you have to for the room. Just get a Shurflo accumulator tank from Amazon.
Old 05-26-2015, 05:19 PM   #24
David B.'s Avatar
Dan,
Dan, I used the same accumulator as Charlie & Sara, only I had to replace my fractured plastic anti-reflux valve (I used a slightly larger brass one), so I had even less room than you did. I placed my accumulator along the wall, by cutting into the PEX and used shark bite connectors.
Dave & Paula
Old 05-26-2015, 05:23 PM   #25
HomeCamp's Avatar
East Tennessee
Dave & Paula
Thanks Dave, If I can't find another cause, That's what I'll be doing.
Dan
Old 05-26-2015, 05:32 PM   #26
HomeCamp's Avatar
East Tennessee
Dan,
Great , Thanks for all of the help. Will get back to you guys if I need further advice when I get around to doing the task. I'm still hoping it just go away!
Dan
Old 05-26-2015, 09:40 PM   #27
Our local Menards sells PEX fittings which are press on, reusable and compatible with the plastic tubing commonly used buy trailer makers.
Old 05-27-2015, 05:04 AM   #28
HomeCamp's Avatar
East Tennessee
Good to know. I've seen them, just never used them.
Thanks,
Dan
Old 06-14-2015, 02:56 PM   #29
My water pump will not shut off with the faucet, it will pump water. It is a casita. What do I need to replace?
Bill castle is offline   Reply With Quote
Need help Installing a water pump on scamp 1979 13' juanka Plumbing | Systems and Fixtures 3 04-21-2015 06:32 AM
Water pressure or pump problem? Janb313 Problem Solving | Owners Helping Owners 10 06-19-2013 10:41 PM
New manual water pump needed, need suggestions Michael Collins Modifications, Alterations and Updates 12 03-16-2010 06:03 AM
A Water Pump Problem? Robert Brummett Problem Solving | Owners Helping Owners 2 06-10-2008 05:24 PM
water pump problem Jamey Plumbing | Systems and Fixtures 11 03-07-2007 11:32 PM
