WATER PUMP PROBLEM-Need Help! - Fiberglass RV
Old 05-25-2015, 06:05 PM   #1
HomeCamp's Avatar
Trailer: SOLD - Lil Snoozy 2014
East Tennessee
Hello,
We have a 2014 Lil Snoozy with a Shurflo RV 4008 Revolution By-Pass Water Pump which has had very little use.
When the water faucet is turned off, the pump continues to "Pulse" and the interior LED lights "Pulses" at the same time. I can't find any water leaks and when the pump switch is turned off, the water pressure doesn't bleed down until the faucet is reopened. All of the lines have been purged of air several times.
The previous owner suggest either the back flow valve is causing problems or the pressure sensor in the pump is acting up. If so, I don't have a clue as how to correct either one. I was hoping someone here has had the same problem and can give me a simple fix. Tried doing a search here with no avail.
Thanks,
Dan
HomeCamp is offline   Reply With Quote
Old 05-25-2015, 06:14 PM   #2
Adding a water accumulator might stop the pump for continuing to cycle
Of you could buy one from camping world.
Old 05-25-2015, 07:04 PM   #3
IllAnnoy
Originally Posted by HomeCamp View Post
Hello,
Thanks,
Dan
Check the shore water inlet or the drain plug on the hot water tank. the shore water inlet is a check valve which when it starts to fail will let small amounts of water out.
also... if you have a toilet, look carefully to see if any water is seeping into the bowl.
Old 05-25-2015, 07:18 PM   #4
HomeCamp's Avatar
East Tennessee
Floyd,
The Snoozy has a Ariston 4 Gallon Electric Water Heater and I'm told it doesn't have a drain plug.
Is the Shore Water Inlet Check Valve located where the water hose connects? If the check valve is bad, does the water come back up the inlet to the outside?
Dan
Old 05-25-2015, 07:55 PM   #5
IllAnnoy
Floyd,
Dan
Yes, the shore water inlet has a little rubber check valve right inside the connection which is intended to prevent water from exiting the trailer when the pump is on. Sometimes it will reseat once you use shore water without the pump. but they are cheaply made and often must be replaced once they start to leak.
Old 05-25-2015, 08:38 PM   #6
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Originally Posted by carol h View Post
adding a water accumulator might stop the pump for continuing to cycle
of you could buy one from camping world.
this is what i did with our lil snoozy, because of the same reason, and it took care of the problem.
Dave & paula
Old 05-25-2015, 11:53 PM   #7
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Dan, I had a class A that started to do the same thing. Turned out to be a water connection sucking a bit of air causing the pump to cycle on occasion and low volts on the battery for the lights. There was no water leaking to show a problem. Just started checking all connections in the line and found one that tightened an 1/8th of a turn and solved the pump cycling. Every once and a while you get lucky and get to keep your wallet in your pocket .
Old 05-26-2015, 12:07 AM   #8
Roger C H's Avatar
Cool Same problem with our well
We had the same problem with our well pump back in Wisconsin.
It was the "Snifter valve" which is supposed to allow the water in the pipe from the submerged pump to drain which draws air into the line and adds this air to the pressure tank. If this doesn't work, the water will eventually absorb all the air in the tank, the tank will become water logged and since water compresses hardly at all, the pressure built up too quickly and the pump would cycle on-off-on-off. The pressure tank prevents this with a cushion of air which compresses, yielding smooth pressure changes in the system.
Old 05-26-2015, 04:35 AM   #9
Trailer: Escape 21 Nov.2016
water
We had the same problem with our snoozy no water leaks we just put in a accumulator and it solved the problem of LED light show everytime we turned on the water
jennykatz is offline   Reply With Quote
Old 05-26-2015, 04:57 AM   #10
HomeCamp's Avatar
East Tennessee
Dave & paula
Your one of three to have suggested an accumulator. I assume it's connected inline on the output side of the pump? What type of connectors did you use? Did you need to remove the jackknife couch to get access? Can't see how you could have installed it through the bottom cabinet door!
Dan
Old 05-26-2015, 05:00 AM   #11
HomeCamp's Avatar
East Tennessee
I will for sure check every connection before adding an accumulator.
Thanks,
Dan
Old 05-26-2015, 05:10 AM   #12
HomeCamp's Avatar
East Tennessee
You and Dave are both Snoozy Owners and Both Agree on the same Solution. Did you install the accumulator yourself? Any suggests on how to do it?
Thanks,
Dan
Old 05-26-2015, 08:42 AM   #13
What worked for me . . .
Dan,
I have the same pump and I also had the same problem. In their troubleshooting section of the manual they mentioned that a restricted inlet line could cause this. They even mentioned in the Installation Preparation section that the culprit could be a restriction caused by a "winterizing valve". I had just installed a winterizing bypass valve, which is about when the cycling problem started. I removed the bypass valve, which was a piece of junk anyway, and the problem went away.
The Winterizing Kit is Camco 36543 Pump Converter Winterizing Kit which I bought and reviewed on Amazon. It got a "1 Star" review from me.
On my system the pump would surge for about 30 minutes after using the water, then it would settle down and stop cycling. It drove me nuts until I fixed it.
Morganza is offline   Reply With Quote
Old 05-26-2015, 09:01 AM   #14
HomeCamp's Avatar
East Tennessee
Originally Posted by Morganza View Post
Dan,
As far as I can see, there is no By-Pass Valve. Not sure how I would ever tell if I had a Restricted Inlet Line?
Thanks
Need help Installing a water pump on scamp 1979 13' juanka Plumbing | Systems and Fixtures 3 04-21-2015 06:32 AM
Water pressure or pump problem? Janb313 Problem Solving | Owners Helping Owners 10 06-19-2013 10:41 PM
New manual water pump needed, need suggestions Michael Collins Modifications, Alterations and Updates 12 03-16-2010 06:03 AM
A Water Pump Problem? Robert Brummett Problem Solving | Owners Helping Owners 2 06-10-2008 05:24 PM
water pump problem Jamey Plumbing | Systems and Fixtures 11 03-07-2007 10:32 PM
