Water Shooting Out of Fresh Water Connection - Fiberglass RV
Old 04-28-2017, 10:18 AM   #1
Ohio
We just de-winterized our Scamp 13. We ran fresh water through the system and flushed it out from all faucets/toilet/shower etc.
We noticed now when we are running the pump located near the sink that water is shooting out of the fresh water connection on the outside of the trailer?
Any ideas why this would happen-it would seem that the water should be going in to grey water tank. We emptied grey water tank and still have same issue?
Thanks
Scott and Linda
sal6342 is offline   Reply With Quote
Old 04-28-2017, 10:51 AM   #2
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
It sounds like you have a stuck check valve or stuck regulator at the fresh water connection. If it is open, the water will flow backwards out of that port. If you have one of those at that point, turn on the water pump and tap on the valve with a metal object to wake it up. If that doesn't stop it you could screw in a plug.
Old 04-28-2017, 12:29 PM   #3
Ohio
Water Shooting Out Fresh Water Inlet
You were 100 percent correct. It was the check valve stuck. Now I know what a check valve is.... LOL
Scott and Linda can now leave for the campground...
Fresh water connection popping off toilet Hettinga Problem Solving | Owners Helping Owners 17 08-28-2016 05:00 PM
Trillium trouble-shooting PatriciaSK Problem Solving | Owners Helping Owners 3 05-31-2016 09:38 AM
Fresh water tank hose connection Kathy L Plumbing | Systems and Fixtures 9 08-19-2012 01:34 PM
Shooting Sports Green Frog Hobbies & Passions 1 07-08-2011 05:26 PM
Water heater trouble shooting (Suburban 6 gallon) Legacy Posts Problem Solving | Owners Helping Owners 12 02-14-2003 11:06 AM
