Water tank for Tahlullah - Fiberglass RV
Old 03-17-2014, 08:24 PM   #1
Tilly's Avatar
Trailer: 1976 Boler 1300
Manitoba
Hello all
Emerging from record-breaking winter in the boler homeland, and projects are almost underway. Can anyone tell me what is the best replacement for my current leaky water tank? Brand or source? And what is a fair price?
My beauty is a 1976 boler 1300.
Saw a great post from 2008 - PDF, w diagrams, with dimensions and stuff...but thought I would dig a bit deeper.
Merci bien
Tilly is offline   Reply With Quote
Old 03-17-2014, 08:44 PM   #2
Dudley's Avatar
Trailer: 1998 Casita 17 SD
the tanks were made by Polyrama Plastics in Edmonton, Alberta and were still being made up to 2 years ago when I bought mine. The company was sold to Norwesco Canada Ltd.
You can contact them and see if they still make them. Cost 2 years ago was $100
model number of the tank is ERT 8.25 Boler
Old 03-17-2014, 10:56 PM   #3
Tilly's Avatar
Manitoba
Much appreciative of the reply. I'll check that out.
Old 03-18-2014, 02:59 PM   #4
Dudley's Avatar
just checked with Norwesco and they do not make the tanks anymore
Old 03-18-2014, 03:17 PM   #5
Ian G.'s Avatar
There are a couple of other options.
Some years of Boler came with the water tank under the dinette seat, I am sure it is a common size that would be available in your local area.
Another option would be what I use, an external water reservoir, easy, inexpensive, you can clean & disinfect it, it does not flavour or add that plastic taste to the water and in hot weather you can add a block of ice so the water is cold.
Some info is on my build thread It Started as a Kitchen Reno- Project Boler
More details are on my Blog
Boler External Water Reservoir | Proud Canadian
Old 04-07-2014, 04:50 PM   #6
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I bought tanks from rvdirect.com and dyers rv. No clue what will fit your camper, though.
Old 04-07-2014, 05:05 PM   #7
Joe MacDonald's Avatar
you could try RV Fresh Water Tanks & Waste Holding Tanks - D&M Plastics Inc. they advertise custom sizes in Ontario
Old 04-07-2014, 05:51 PM   #8
Trailer: 2014 Escape 21
Virginia
I was just on E bay looking a Velterra products. I saw several fairly inexpensive ABS fresh water tanks tanks made by them and you can also buy the connector kit for them also on E-bay which they just glue to the tank. The tanks are black in color but are for fresh water. These look like the tanks Parkliner uses for fresh water. The other fairly inexpensive option is buy a Scamp tank, they have two sizes.
Eddie
Old 04-07-2014, 07:02 PM   #9
How about giving Joe at Trillium in Calgary a shot - he may have something that works for you or a suggestion on where to find.
Old 04-07-2014, 07:35 PM   #10
David Tilston's Avatar
How about giving Tom at Trillium in Calgary a shot - he may have something that works for you or a suggestion on where to find.
Umm.... Tom Young owns Trillium in the US. Joe Thoen works out of Calgary. Joe will probably have something.
Actually, I have something, but it is old, and Manitoba is not so close. I will post pictures in about an hour.
Old 04-07-2014, 08:17 PM   #11
David your absolutly right! My slip.... should have read Joe.
Old 04-07-2014, 09:00 PM   #12
One Tank for Free
It is old, it needs cleaning and there is damage to the white port. See pictures.
Also, I think it is designed to lay down. Standing 10" tall, with a foot print of 16" X 17". Since you would want the drain on the bottom.
I think this tank can be modified. Have a port added to the bottom, as it appears in the picture. Probably should add one to the top for a vent. The damaged port can be plugged off.
Old 03-04-2015, 01:23 PM   #13
Trailer: Boler 1972
Boler exterior 10 gallon water tank
I was wondering if anyone has recently found a replacement for their exterior mounted 10 gallon Boler freshwater tank. I would prefer it remain exterior mounted.
Thanks!
Sandra in Edmonton is offline   Reply With Quote
New water tank and exterior tank fill "door" Treedles Modifications, Alterations and Updates 10 10-11-2013 10:38 AM
Introducing Tahlullah & storage Q. Tilly Care and Feeding of Molded Fiberglass Trailers 4 08-12-2013 07:08 PM
Trouble adding water to a fresh water tank Dan Tracy Problem Solving | Owners Helping Owners 1 05-05-2008 08:11 PM
