What is the best hot water hose to use? - Fiberglass RV
Old 02-12-2006, 07:12 PM   #1
Trailer: X-treme Lite 160
I am adding a Tiny Titian hot water heater to my Scamp during my total restoration. I purchased it at Lowes for $165.00. It holds 2.5gals pulls 11.25amps. Really heats up fast. I used the Braid PVC (1/2"ID) tubing for all pumping. But, I am having trouble getting the Hot water side to seal on the brass hose barb at the hot water side of the faucet. I think it is due to the expansion. What would be a heat rate hose to use with the hose barb that would be ok to drink from? I'll post a few pictures.
Thanks,
Gary
Gary Little is offline   Reply With Quote
Old 02-12-2006, 08:42 PM   #2
Craig Nold's Avatar
Trailer: 1999 Casita 16 ft Spirit Deluxe
Gary,
Thatís a good looking plumbing job. You used the same type of tubing that I would have. It looks like the tubing that I got at my local farm supply,. Do you have room to double clamp the barb that is leaking?
Craig Nold is offline   Reply With Quote
Old 02-13-2006, 12:01 PM   #3
Brian B-P's Avatar
I would ask an company that does commerical food-preparation facilities what they would use for hot-water washdown hoses - I assume that those are potable water grade. Maybe there's a potential fit to the desire for a flexible hose for potable hot water.
Old 02-13-2006, 08:58 PM   #4
Gary,
That’s a good looking plumbing job. You used the same type of tubing that I would have. It looks like the tubing that I got at my local farm supply,. Do you have room to double clamp the barb that is leaking?
Hi Craig,
Thanks for your reply. I actually got some good help today at Lowes Hardware. The plumbing guy suggested coupling to faucet supply lines together to make my 42" length needed from the water heater to the faucet. It was an additional 8 bucks but it woked great. He said it is virtually impossible to get a hose barb and clamp to seal good on the hot water side. See photo's of my progress.
Thanks,
Gary
Old 02-13-2006, 09:01 PM   #5
Steven Tonnesen's Avatar
Trailer: casually shopping
Send a message via Yahoo to Steven Tonnesen
For hot water, I would recommend the use of copper tubing. Yes, it weighs more, but leaks can kill the wood floor, which is a PAIN to replace.
Steven Tonnesen is offline   Reply With Quote
Old 02-13-2006, 10:12 PM   #6
Howdy, Is Pex water pipe available in the US.....this is the white poly line that uses the crimp on type fittings......possibly this type may be the best to use in RVs.....It is widly used in new home construction up here now.....Benny
Old 02-14-2006, 05:40 AM   #7
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
The braided steel faucet hose idea was a good one. I'd not have thought of that! I probably would have used a nylon fitting with a hose barb. Screw the fitting onto the faucet inlet, then attach your hose and hose clamp. Nylon will seal to a brass faucet, and the hose and hose clamp will seal to the nylon fitting.
Roger
Old 02-14-2006, 09:24 AM   #8
As Benny said, use PEX (cross linked polyethylene) tubing.
Your hardware store should have Flex Pex along with compression fittings to connect to about anything. Here's a source on line:
PEX
Morgan is offline   Reply With Quote
Grey water overflow hose Fran L Problem Solving | Owners Helping Owners 3 07-06-2009 09:22 AM
sterilizing water tank and hose questions brenjean Plumbing | Systems and Fixtures 7 07-25-2006 09:37 PM
Water Hose Storage Thane Problem Solving | Owners Helping Owners 0 06-04-2006 02:20 PM
coiled water hose Legacy Posts Modifications, Alterations and Updates 1 03-05-2003 07:57 PM
