Winterizing Scamp for first time. - Page 2 - Fiberglass RV
Old 10-20-2015, 01:06 PM   #15
Sid
Sid's Avatar
Trailer: Parkliner 2014 V6 Jeep Cherokee
Does anyone else relieve the backpressure in the lines after running the pump? I do not see it listed in any of the threads but one of my final steps is to remove the screen in the city water connection and then push in on the valve located underneath. This will "burp" the lines, allowing some water and then AF to spurt out. Replace the screen and your good to go!
Sid
Don't quit your daydream.
Sid is offline   Reply With Quote
Old 10-20-2015, 01:27 PM   #16
Thank you Sid for bringing that out! I do that as well. And you HOPE to see "pink" come out. (Although there's no screen I remove on the Scamp..just press the plunger)
Sid
Old 10-20-2015, 01:49 PM   #17
Sid
I do. Once all the lines are completely full (many of the lines on my trailer are clear so I can see they are fully loaded with pink Anti freeze) I turn the water pump off and then open up the taps one at a time and some of the anti freeze will normally come out of the tap - that will also let off the pressure in the lines. Can actually see the amount of pink in the lines drop down. My theory is as long as the only liquid in the lines is anti freeze they don't need to be completely full of it.
I do as a previous poster mention make sure ALL my holding tanks are drained prior to winterizing. To completely drain the fresh water tank I need to lower the trailers tongue down as the tanks drain is located at the bottom of the tank at the forward end of the tank. If the trailer is sitting level the fresh water tank does not completely drain. If I were to add anti freeze to the fresh water tank without making sure it was completely empty first the anti freeze going through the trailer lines would be diluted.
I also do not leave an anti freeze in the top portion of the toilet over the winter. I actually don't leave any anti freeze in the toilet at all. I drain the tank right out once I have filled the water line leading to the toilet with anti freeze. I actually don't leave any water in the toilet anytime the trailer is in storage. Never had a problem as a result of that practise.
Old 10-20-2015, 05:50 PM   #18
Trailer: 2000 16ft Scamp
In addition
I named my Norwich Terrier 'Manny' after Manny Ramirez. Now back to winterizing....I store my Scamp at a retired turkey farm building so rodents are a concern. I use a product called Botanical Fresh Cab rodent repellent which is primarily Balsam Fir Oil in plant fibers. Found it on Amazon. I put one under each seat space and one up front under the bunk. I also put one under the sink. Mice and chipmunks stay out and it smells great. I have always put two gallons of fifty below in my water tank run it through the faucet and toilet. I have no hot water heater. The worst part about winter is we don't have our Scamp.
John
crowwing is offline   Reply With Quote
Old 10-21-2015, 08:38 AM   #19
Trailer: Oliver
As a slight addition to the above - for anyone that has an "outside shower", don't forget it as you go around opening/closing faucets in order to get the AF through the pipes.
Don't ask why I know this!
topgun2 is offline   Reply With Quote
Old 11-06-2016, 02:03 PM   #20
Ohio
Winterizing Scamp last step
We winterized our 13 foot Scamp today using all of the good advice in this posting. We only have one question on the last step. Do you empty Grey and Black tanks after doing the winterizing with the antifreeze. According to Scamp website this is the last step. We just cannot figure out why we would empty. If this is a really dumb question please forgive us. I think all the other steps were clear and I liked the tip in putting your finger over the faucet!
Thanks once agin for all the great people helping each other in this forum!
Scott and Linda and SALLEE (our Scamp)
sal6342 is offline   Reply With Quote
Old 11-06-2016, 03:21 PM   #21
I never have. I DO always make sure I drain the tanks to make sure there's no residual water in there BEFORE I winterize. But no, I do not pull the valves once I run the RV antifreeze through. That's just me and have done it that way for 6 yrs. Personally, I dont think it would matter either way.
Old 11-07-2016, 08:34 AM   #22
I do. One of the issues with the design of Scamps grey water (as well as a number of other brands of trailers) is there is a lip on the discharge side of the grey tank that prevents the tank from completely emptying unless you have the trailer sitting tilted over to the discharge side. If not although you have put anti freeze down into the tank it is very diluted due to the water that is still trapped into the tank.
First time trailer owner going full time! Sarandipity Hi, I am.... 23 11-27-2015 10:46 AM
First Burro, first post, first question :) Can i lie on the roof to do vent work? Colleen Rae Hi, I am.... 13 03-30-2015 08:38 PM
Long time snooper, first time poster - Hello! Joe & Cherie Hi, I am.... 5 03-20-2014 09:38 AM
First time owner with a '76 13' Scamp markism Hi, I am.... 1 08-28-2012 04:32 PM
First Time Storing of Scamp barryra General Chat 3 08-24-2010 09:08 PM
» Trailer Showcase
Scamp
bippygma
Burro
AdamB
